Author Topic: 750F thread?  (Read 168076 times)
Offline topgun
Re: 750F thread?
« Reply #950 on: December 31, 2012, 07:11:50 PM »
Hey guys,I have a F1 with s/bores and ramflo filters wondering about the running of  breather hoses eg rocker cover hose, c/case hose, oil tank hose and would I do away with the canister all together any ideas appreciated cheers tony
Re: 750F thread?
« Reply #951 on: January 01, 2013, 04:21:50 PM »
G'Day Tony, The rocker box breather hose can just vent into the atmosphere, the crankcase breather should go into the back of the oil tank, the oil tank breather can vent into the atmosphere. Cheers, Terry. ;D
Offline topgun
Re: 750F thread?
« Reply #952 on: January 05, 2013, 12:54:43 PM »
Thanks Terry I think the way I had it set up I was pressurising  the crankcase .The F oil tank has only 1 breather at the bottom where as the k,s have 2  8)
Offline topgun
Re: 750F thread?
« Reply #953 on: January 05, 2013, 02:37:38 PM »
this is my F hope you guys like it
Offline Vreihenmotor6
Re: 750F thread?
« Reply #954 on: January 05, 2013, 02:46:56 PM »
looks nice, is that the corbin seat? any closer pics? what cover pattern did you select? I'm looking for a pattern that will look time frame appropriate for when I get mine
Offline andrewk
  • doin' it.
Re: 750F thread?
« Reply #955 on: January 05, 2013, 02:47:15 PM »
I'm looking for a 77-78 rear master cylinder-  anyone have one they'd be willing to sell?  The two on ebay look like crap for the price...
Offline dlhoulton
Re: 750F thread?
« Reply #956 on: January 05, 2013, 03:16:10 PM »
Topgun, love the bike. That is one clean looking bike. I got to ask about those RAMFLO filters. Love that look and style. First off what was your source for the filters? Second question, how are your carbs set up for those filters?
dlhoulton
Offline topgun
Re: 750F thread?
« Reply #957 on: January 05, 2013, 04:22:48 PM »
Thanks  for the good comments The seat is standard but scolluped out and been recovered with stiching running left to right. I found the ramflo,s at a swap meet,they were for a stock Honda/4 set up ,I just made the holes in the plate bigger and glued rubber tubing to suit carbs, The various parts for romflo,s are readily available.Thejets are 120,s and needle clip 2 nd from bottom I,m running 900 MTC Ivan Tighe 319 cam Dyna coils and ignition Cheers Tony
maduncle
Re: 750F thread?
« Reply #958 on: January 06, 2013, 01:32:22 AM »
Pretty sure I have one in my CB750 parts box in the shed, hang on a moment and I will go have a look...
Yep. I still have a good one, 1977 CB750F2 rear master cylinder, mounted on that big arse alloy bracket, complete with the passenger foot peg!
Postage from Australia might cost a bit, but you can have it cheap - PM me to discuss.
Cliff
Re: 750F thread?
« Reply #959 on: January 06, 2013, 12:24:42 PM »
Didn't BrandEn just post up a rear?
Offline brandEn
Re: 750F thread?
« Reply #960 on: January 06, 2013, 12:25:26 PM »
Yup, I sent him a pm
Offline calikid
750F thread?
« Reply #961 on: January 21, 2013, 09:43:54 PM »
Anyone know where I can get a set of piston rings for a 78 cb750f. Cant find them anywhere.
Re: 750F thread?
« Reply #962 on: January 21, 2013, 10:17:10 PM »
Did you try ordering from Honda? It recently came up that they are available. I took a look and it APPEARED they are once again available. Whichever dealer you order from would have to order for you just like most of these old parts.
She lives once again
« Reply #963 on: January 21, 2013, 10:19:47 PM »
Today. Same bike, different skin
maduncle
Re: She lives once again
« Reply #964 on: January 22, 2013, 01:57:49 AM »
Well that's different.
So you painted the bike blue on one side and orange on the other side then?
Re: 750F thread?
« Reply #965 on: January 22, 2013, 03:13:19 AM »
^^^  ;D ;D
She sure is pretty!  What color is the orange?
Offline RSchaefer
Re: 750F thread?
« Reply #966 on: January 22, 2013, 09:01:25 AM »
What a beauty Jerry.  Hey what size Spitfires are you running?  I just sent this over to Mark (Hondaman), but have not heard back yet!  What do you think??
So specifically I said to him relative to my desire once the bike is setup: "So as a VJMC member my intent would be to ride it on short weekend rides, not a commuter bike, and not a touring bike, I have my ’05 Goldwing for that.  I would like it to be a nice responsive fast rider.  I do like high speed sweepers and would like to accelerate quickly from the stop light."
1st, this was the response he had given me regarding other stuff (jets, needles, front sprocket, etc., not included herein) but specifically tire sizes:
"So, about the tires: if yours has the 17" rear wheel, you probably would like the widest front tire you can fit as the rear tire will likely be a 130 profile. If, for example, the front is a 100/90x19 and the rear is 130/90x17, the roll-over roundness profiles will be bigger on the rear than on the front. When in fast corners, this makes the bike feel like it wants to roll down more into the turn as you increase power, because the rear tire accelerates ever so slightly as the bike is heeled over, relative to the front tire. This means the rear feels like it is trying to "slide out" (as is often the description) when power is applied while heeled over. As the round side profiles begin to match each other closer, this begins to neutralize this sensation. Some of it can be controlled with tire pressures: for example, I run:
38-40 front and 36-38 rear when using 100/90x19 front and 110/90x18 rear (or 3.25x19 front with 4.00x18 rear), or
36-38 front and 34-36 rear when using 110/90x19 front and 120/90x18 rear (or 4.10x19 front with 4.50x18 rear, in TT100 profiles of old).
So, when picking out your tires, go to shop where the tires are, and pull out both sizes. Set then in line with each other, then lean them over and watch their centerlines as you do: this will explain in a second what I am trying to describe. The rear tire (wider, heavier load) simply rolls over at a different radius from the front (narrower, lighter load), and it's up to you to figure out which profile and tire pressures will neutralize this for that smooth sweeper. This was 50% of road-race handling issues when I did it."
My questions back to him:
"I have an 18" rear (4.00"X18") & 3.25"X19" front, I think stock on the '75F for sure and probably the '76F as well, not sure about the '77/'78F's.  In reading your book again (Suspension and Handling) and alluding to what you said below (now above), I had been thinking about the larger front tire 3.50 verses 3.25.  Specifically I was thinking the Bridgestone Spitfires (S11).  So my options in the S11 would be 90/90X19, 100/90X19 or 110/90X19 in the front and 110/90X18 or 120/90X18 in the rear.  They also offer a 130/90X18 for the rear.
So I'm a little confused on the tire size issue and going back and forth between metric and std. it would appear the closest std today to stock would be a 90/90X19 on the front (3.25") and the 110/90X18 on the rear (4.00").  Your book recommends a 100/90X19 front (3.50") or 110/90X19 (4.10", TT) and a 5.10" TT in the rear or what I'm thinking would be the 130/90X18 S11.  So I'm thinking the best choice for me would be the 110/90X19 in the front and the 130/90X18 in the rear.  Do you think those S11's would fit, front and rear, or should I just stick with the 110/90X19 in the front and 120/90X18 in the rear?  Do you have any concerns with the Spitfires or do you have a better preference?"
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline andrewk
  • doin' it.
Re: 750F thread?
« Reply #967 on: January 22, 2013, 09:25:25 AM »
My experience with 130's in the back (several brands) is that they really are too wide for the rim.  They "crown off" quickly if you're not riding a lot of corners.  I've had much better wear with 120's in the rear, seems they wear more evenly, and the bike feels more nimble too.
Any tire with a non-directional tread should feel nice on modern grooved highways. Spitfires are good- lots of guys using AM26 Avons and BT45 Bridgestones too.
« Last Edit: January 22, 2013, 09:26:58 AM by andrewk »
Offline mysta2
Re: 750F thread?
« Reply #968 on: January 22, 2013, 10:04:49 AM »
Mine (as of a few weeks ago):
Hopefully I'll be putting the motor back together soon, It's starting to warm up out there!
Re: 750F thread?
« Reply #969 on: January 22, 2013, 10:59:27 AM »
Damn, I really like that front end. My next project will be like your's with all my take off stuff on a spare frame. Details!
Stock NOS tank with Flake Sunrise Orange
100 front with 120 rear - sure wish we could still get the white letters! I bought those tires a few years back and they have been awaiting this moment
Offline mysta2
Re: 750F thread?
« Reply #970 on: January 22, 2013, 02:02:20 PM »
Are you asking me for details? If so, most of them can be found here http://dropbarscinder.blogspot.com/
But the summary is:
Bought this bike about a decade ago out of a junkyard, then sold it to a friend (after sitting on it for a few years), who sold it to another friend, who eventually sold it back to me.
Bent front end swapped to the take off from my '96 VFR (all that needed to be done was swap the stems)
Issues with first gear led to stripping the motor down...
Broken oil ring led to 836 bore
and now it's all in pieces, painted up, and ready for re assembly
Offline RSchaefer
Re: 750F thread?
« Reply #971 on: January 22, 2013, 03:42:45 PM »
Why not 110's on the front Jerry?  Back in the day I would just paint the Bridgestone w/white paint, is that not an option?  I guess the stock tire does not have "raised" letters?
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Re: 750F thread?
« Reply #972 on: January 22, 2013, 06:03:53 PM »
100mm = 3.94" = Larger than stock. Don't know if I ever considered a 110?? Never really got into the analysis/whys/why nots?? Went with what was available and worked. Guess you could bump front and back up one notch over what I'm using and they'd fit.
Offline HonderCB
Re: 750F thread?
« Reply #973 on: January 24, 2013, 01:45:07 PM »
LOOKS F-IN SWEET JERRY!
77' CB750F
81' CB650C - SOLD
Offline RSchaefer
Re: 750F thread?
« Reply #974 on: February 01, 2013, 06:14:41 AM »
Hey I have a question, maybe already asked and answered, sorry if so.  What does the "F" stand for?  I was exchanging emails with Hondaman this last few weeks and he was saying the (CB750) "K" stood for Kaizen ("Kaizen means "improvement". Kaizen strategy calls for never-ending efforts for improvement involving everyone in the organization – managers and workers alike.").
So I asked Mark about the "F" and he said he asked a guy from American Honda that question and he stated something like "F" stood for the "F" in four as in four cylinders, but Mark did not think the guy knew what he was talking about.
Anybody else really know why Honda called our bikes "F's"?
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
