Author Topic: Cold weather starting tips  (Read 1786 times)
ElCheapo
« on: November 18, 2005, 01:56:01 PM »
As we begin to fight off the cold weather there are some tips I used in the days of automotive repair that may help. So maybe these helpful tricks will work on cars and trucks too.
Motor that starts very hard in the cold. The kind that grinds the battery to dead in less than 3 minutes.
1. Battery must be a little warm to get the maximum cranking amps from it. A frozen battery works for #$%*e.
2. You have cranked away and she still refuses to start - Warm spark plugs with a propane torch (make sure the propane is room temp before you use it as it will not provide a proper flame) and for God sake do not heat these in anyway as they can burst, which WILL ruin your day. Remove your plug wires first please.
3. Use platinmum plugs. These fire nicely even when fouled with fuel. I have no opinion on split fire plugs, have yet to try them.
4. Using 500 watt halogen lights to warm an engine does help a lot.
5. Warming carb(s) with hair dryer can ease starting problems. Please do remember that you are using fire in a fuel situation.
6. Here is good idea if you have a contractor that is a siding fool. Get a piece of Tyvek house wrap that will cover your bike. Place this black side out in light sun. In a short period of time the bike will be in summer like temps under the Tyvek. I used a piece to save my but on Mount Antero when the weather went bad. Wet yes, warm yes. I believe black tarp will have similar effects.
« Last Edit: November 18, 2005, 01:59:15 PM by ElCheapo »
Offline cb350f_rider_73
Re: Cold weather starting tips
« Reply #1 on: November 19, 2005, 12:01:17 AM »
Hmm...ever tried kicking the kickstarter a few times with the key off to circulate the oil a bit before starting?  That seems to be a good idea to me.
Wayne
1966 Honda CL77 Scrambler
1973 Honda CB350F (see avatar)
1979 Yamaha XS11 Special "The Beast"
Jim Shea
« Reply #2 on: November 19, 2005, 02:01:44 AM »
How a bout keeping the poor old girl in a nice warm place?
« Reply #3 on: November 19, 2005, 02:05:58 AM »
Alas, I have no such option.  Otherwise, I would do so gladly.
Wayne
Jim Shea
« Reply #4 on: November 19, 2005, 02:12:44 AM »
Wayne,
What are you doing up this early on a Sat morning?
Is ther such a thing as an 'outside' bike cover? I have an 'indoor' one but it just keeps dust off the bike.
Jim.
Offline Harry
    • CB500F
« Reply #5 on: November 19, 2005, 02:52:39 PM »
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
« Reply #6 on: November 19, 2005, 10:35:49 PM »
Up early?  I was up late with a horrible case of insomnia.  It was either surf the web or lie in bed counting  the little dots in the ceiling spackle.
Wayne
Offline 78 k550
« Reply #7 on: November 21, 2005, 06:15:10 AM »
for my 72 cb500, I do what the manual say's and it fires right up. Choke completely closed 1/4 throttle and away she goes. Just be ready to crack the choke open a bit right away.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Jim Shea
« Reply #8 on: November 21, 2005, 06:33:16 AM »
I'll have to try that. I do the opposite, choke full open, no throttle, it fires instantly and I close the choke almost immediately..
ElCheapo
« Reply #9 on: November 22, 2005, 06:29:18 AM »
Harry - awesome info on your page there. I will have to try some stuff like that.
Offline Jonesy
  • Shop Rat
« Reply #10 on: November 22, 2005, 08:07:05 AM »
Honda recommended putting on the choke and kicking the bike several times with the ignition off. This primed the engine and got the oil going as well.
