Author Topic: 350F plug chops.. I finally got a chance to do it.  (Read 852 times)
Offline fmctm1sw
« on: July 19, 2009, 04:32:20 PM »
Well, here it is.  My bike (seemingly) runs real good.  I looked at my plugs during a 1000 mile service and they were black :(   So here they are:  1/4 throttle first and then 3/4 to full (I was more watching the road than the marks on my throttle on that one).  The 1/4 chop I rode over 3 miles, had a lot of wide open space.  The 3/4 full not near as far, only enough to run it up to 80 or so.  Thoughts?
*edit* and I don't know if you can see it but there's a deposite of some sort on the electrode on 2, 3, and 4 of the 3/4 to full plugs..
Trying to add bigger pictures...
« Last Edit: July 19, 2009, 04:53:07 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Flying J
Re: 350F plug chops.. I finally got a chance to do it.
« Reply #1 on: July 19, 2009, 04:38:22 PM »
I need to do a plug chop too. What plugs did you use? Cheap ones or standard.
Offline fmctm1sw
« Reply #2 on: July 19, 2009, 04:39:31 PM »
Ah good point.  These are NGK D7EA which is one range hotter than standard.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #3 on: July 19, 2009, 11:45:24 PM »
First thing to cure/solve is why they aren't all showing the same deposits.
Valve adjust.
Compression numbers.
Ignition timing/ ignition lead inspection.
Carb boot sealing
Carbs clean with in-spec parts, adjusted equally. (and synchronized)
Air inlet differences/ choke butterflies proper.
Any exhaust obstructions?
« Reply #4 on: July 20, 2009, 07:30:52 AM »
Valve adjust.
Carb boot sealing
+1 on all of the above.
#2-3-4 look ok(tan) on your 3/4-full, but might show different if you were able to run it longer to get a more accurate result. #1 looks a little lean.
