Author Topic: Chain recommendations please?  (Read 4931 times)
Offline Dennis
Re: Chain recommendations please?
« Reply #25 on: November 20, 2005, 06:21:24 PM »
I have a 750K8 and run a 630 chain...some like a 530...will you be doing the 530 convertion?
Don,
'75 - '76 CB750 F or F1 (whatever you want to call them) have 530 chain standard.
The 630 chain was later, I'm not sure when they made the change.
Jim Shea
« Reply #26 on: November 21, 2005, 01:44:15 AM »
Dennis,
Can you explain please?
"BTW I find it easier to "break" the bolts before I remove the chain, that way you have the option of using the rear brake to hold it for you"
Also, what is the difference between a 530 and a 630?
Jim.
« Last Edit: November 21, 2005, 01:51:56 AM by Jim Shea »
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #27 on: November 21, 2005, 03:26:26 AM »
I think he means when you put a wrench to the front sprocket bolts, the sprocket is going to want to turn on the shaft. If you have someone handy, they can step on the rear brake which will hold the rear wheel and thus make the chain taught and prevent the sprocket from wanting to turn. The 530 chain is narrower than the 630, by how much I don't know.
Jim Shea
« Reply #28 on: November 21, 2005, 04:10:48 AM »
Thanks. I will stick with 530 then no clearance problems that have been referred to here!
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #29 on: November 21, 2005, 04:33:48 AM »
Jim, the 530 / 630 refer to the chain size in 1/8th inch increments.
Thus a 530 chain has a pitch of 5/8" and a width of 3/8"
A 630 chain has a pitch of 6/8" (ie 3/4") and a width of 3/8"
Good ol' imperial measures...
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Jim Shea
« Reply #30 on: November 21, 2005, 05:07:50 AM »
Steve,
Thanks. I assume pitch is height of the chain then?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #31 on: November 21, 2005, 05:19:28 AM »
Jim,
You might find this info useful.
http://www.gizmology.net/sprockets.htm
    • TVAM
« Reply #32 on: November 21, 2005, 05:35:25 AM »
Nope.
Pitch is the distance between the links (or the distance between the "points" of the sprocket)
EDIT: Just read Bob's post, which just about sums it up.  Think I'll put it in the FAQs.
« Last Edit: November 21, 2005, 05:37:15 AM by SteveD CB500F »
SOHC4 Member #2393
Jim Shea
« Reply #33 on: November 21, 2005, 06:30:35 AM »
Thanks, it certainly does say it all.
Interesting comment below:
The smaller the pitch, the less noise, wear, and mechanical losses will be experienced.
    • TVAM
« Reply #34 on: November 21, 2005, 07:14:55 AM »
Yes but there is a trade off between "smallness" and the ability to transmit horsepower and last a reasonable time!
SOHC4 Member #2393
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #35 on: November 21, 2005, 05:25:13 PM »
Get a quality brand name chain such as: Tsubaki , D.I.D. , Regina or RK and keep it clean and lubed.
 But note that some of these manufacturers such as RK also sell economy chains made in Malaysia , stay away.
I put over 20,000 miles on my `72 this year and I bought one of these  Malaysian made chains from the local Honda dealer because it was the only one he had in stock at the time. It only lasted around 5,000 miles , it rusted imediately after a light mist and all of the pins were worn.
I now have a D.I.D. on it and in 15,000+ miles have only had to tighten a few times , hardly any stretch at all. Even after riding  back from Chicago 6 hrs. in a steady downpour it didn`t develop any rust.
Bottom line: Maintenance and more maintenance ;)
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
« Reply #36 on: November 22, 2005, 06:36:12 AM »
I use Tsubaki Sigma O-ring chains on my CB750s (K4s) - 16,000 miles on the last one - and this chain had plenty of varied ridiing over a 2 month, long distance trip - deserts, mountains, beaches, rough roads. Im a believer in Tsubaki! :-). Worth the extras money for sure.
Cheers
Andy
