Author Topic: Wiring for constant loss has me at a loss!! 77 CB750K  (Read 815 times)
Offline bikebitzofvt
« on: July 19, 2009, 05:17:59 PM »
Ok, I'll admit it's been several years since I've done this.  I'm trying to see if my 77 750K (now known as Frankenbike) will run before I get too deep into the project.  After I pulled off the fried wiring harness, I took a quick dash thru the carbs, eyeballed points gap and hooked up a battery "constant loss."  I checked for spark and got nothing...
If I'm thinking correctly, it should be:
- connect the blue at coils to blue from points
- connect the yellow at coils to yellow from points
- 12V+ to the black/white wires at the coil
- 12v- to ground.
Kick and get spark, right?
This is what I tried with zero spark result.  I'm headed back down to try a known good points plate and condensers, if anyone could chime in it would be greatly appreciated!
I'm really awaiting that exultant mad scientist "Bwahahahahaha!!! It's alive!" moment...
« Last Edit: July 19, 2009, 05:41:27 PM by bikebitzofvt »
"If it ain't broke you aren't riding it hard enough!"
77 CB750K7, 77 KZ1000B
Offline Kevin D
  • SE Michigan
Re: Wiring for constant loss has me at a loss!! 77 CB750K
« Reply #1 on: July 19, 2009, 06:58:38 PM »
Heres a K1 wiring diagram you can eliminate all systems except ignition, just click in the "off" box:
http://oldmanhonda.com/MC/wiring750K1.html
Looks like you have it right, is your battery charged?
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #2 on: July 19, 2009, 11:18:12 PM »
Battery to kill switch
 kill to coils
