Author Topic: Oil tank cb/cr 750 '73  (Read 797 times)
katman1260
« on: July 20, 2009, 01:56:58 AM »
Hey all, first post here.
I have a 73 cb750 that is being turned into a cafe. I need to know what all the ports are for on the oil tank as I need to make a new one. Volume would be good too.
thanks,
Offline azuredesign
  • Knupping pin
Re: Oil tank cb/cr 750 '73
« Reply #1 on: July 20, 2009, 04:18:40 AM »
I believe the original has, aside from the uppermost filler port, separate send and return ports at its lowest point, along with a tapped hole for drainage. On the back side, there are upper and lower vent ports. I would say that 4 quarts would be adequate for the oil tank, 3 for the motor and 1 just in case of overfilling, but others will know more.
katman1260
« Reply #2 on: July 20, 2009, 08:50:36 AM »
thanks for the info.
here is a pic. the upper vent has a disc on the back? filter maybe?
anyone know of an aftermarket alum/racing tank available??
« Last Edit: July 20, 2009, 08:52:28 AM by katman1260 »
