Author Topic: LESTER MAG peoples?!!!! (tires)  (Read 2156 times)
Offline SKTP
« on: July 21, 2009, 12:12:40 PM »
So I go them back from the powder coater and they look awesome...being an idiot, I forgot to take pictures of the info printed on them...They are 19" Front and 18" back.
- Anybody have this info?
- Are these tube or tubeless?
- what tires are you running or would recommend?
thanks SOHCers  :)
« Last Edit: July 21, 2009, 02:16:04 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline mcpuffett
Re: LESTER MAG peoples?!!!! (tires)
« Reply #1 on: July 21, 2009, 12:34:09 PM »
I'm running Melber Alloy wheels on my Kettle and using inner tubes also ,don't know if that helps you, cheers Mick
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
WHALEMAN
« Reply #3 on: July 21, 2009, 01:44:20 PM »
They are tube type only and same as stock size. I bought mine in the late 70's. I can look for my old paperwork, scan and e-mail to you. I have done this once before. Dan
Offline SKTP
« Reply #4 on: July 21, 2009, 02:13:24 PM »
WHALEMAN, that would be amazing! Please email to c_bywater@yahoo.ca thanks a million :)
I am new to tires but I was just quoted $240 for a set of Avons that I believe will fit...the front is 100 wide and the rear 150...will my 78K accomodate wheels that wide? I want to go as wide as I can...my friend thinks I am an idiot and should keep the stock widths...what do you all think?
« Last Edit: July 21, 2009, 02:16:34 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
WHALEMAN
« Reply #5 on: July 21, 2009, 02:58:37 PM »
I will e-mail tonight. Search for hondaman posts on tire sizes. You really do not want to go as wide as possible. When I get home I can also search for the excellant write up by Hondaman on tire sizes and handleing. Dan
Offline SKTP
« Reply #6 on: July 21, 2009, 03:16:13 PM »
Thanks Dan...how awesome is this Forum?!   :)
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
EverettShadowbrook
« Reply #7 on: July 21, 2009, 03:42:37 PM »
WHALEMAN
« Reply #8 on: July 21, 2009, 04:39:18 PM »
All I could find was some installation instructions that did not mention tubed or tubeless. I am 100% positive that my set of Lesters were ONLY to be run with a tube. The bead and filler hole are both designed for tubed tires. I remember a paper with this warning on it. I hope this helps. Dan
