Author Topic: 1978 Honda 550/Charging system  (Read 1068 times)
Dragon
« on: July 22, 2009, 09:38:27 AM »
I am having a problem with my charging system, the bike needs to be at 2000 RPM before the current at the battery reaches 13.5 volts. I have gone through and cleaned all connections i found and made sure the head light and tail light are OEM. This does have a vetter windshield with the annoying buzzer on the blinker. I was looking at the handaman ignition to reduce load on the battery. Anyone have any suggestions? Thanks.
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: 1978 Honda 550/Charging system
« Reply #1 on: July 22, 2009, 09:45:00 AM »
You might want to move this to the tech thread. You'll want to talk to Bob about that.
Offline kirkn
« Reply #2 on: July 22, 2009, 04:10:10 PM »
Welcome aboard!
IMHO, if you're getting anything above, say, 13 volts at the battery terminals at an RPM just above idle (2000), you don't have a problem at all.  I mean, after all, you're charging up above the nominal battery voltage at an RPM that you'll nearly always be above, except when idling at a stop light or something.
Just go ride!!
Offline BlindJoe
« Reply #3 on: July 22, 2009, 05:42:12 PM »
yeah thats normal, and if the buzzer annoys you disconnect it
Offline Tretnine
  • Prove it,
  • Figuring it out, one expletive at a time.
    • http://www.behindbarsmotorcycle.com/
« Reply #4 on: July 23, 2009, 05:55:39 AM »
Posting in agreement. You don't get much charging on the low side of RPMs, just the way they come.
2009 Kawasaki Concours, 1978 cb550k, 2006 BMW F650GS
Member of the AMA
