Author Topic: Tips for Cam Install?  (Read 4125 times)
Offline nrd2052
« on: July 23, 2009, 09:58:13 AM »
I have a cam from an 82 650 that is on its way and I have been reading all i can so i will be prepared to drop it in to my '74 550.
I have yet to find (in one place) a write up on how to do it, so I am wondering if you guys can provide any tips or tricks for me. I have read the article on how to get the chain back on the sprocket and i think I am good there. I know that i will need to reuse the stock 550 gear and that my tach will no longer be functional.
I am still a little fuzzy on how to put the cam in with the right orientation so that it is timed properly.  I saw the article on degreeing the 750. Does the same hold true for a 550?
Any tips for me? Anything that I should be thinking about that i am not aware of?
Thanks in advance!
--Neall
Offline Gordon
  • 750K1, 550K2
Re: Tips for Cam Install?
« Reply #1 on: July 23, 2009, 10:04:08 AM »
Do you have a shop manual?  The procedure for setting the camshaft to be in correct time with the crankshaft is detailed there.  It's a pretty straight-forward task.
Offline turboguzzi
« Reply #2 on: July 23, 2009, 10:06:55 AM »
cyls 1-4 at TDC, slot in the cam pointing at the 9th hour exactly.
easy, if you miss one gear tooth you'll sure see.
TG
Offline d3buttz
  • More than just an
« Reply #3 on: July 23, 2009, 10:29:41 AM »
lots and lots of patientce, i dont know how many different combinations i tried.   the chain/gear placement is critical when you slide the cam thru them. if its not setup right, its impossible to get the chain on the gear and still have the correct aligning.  now if i could remember how i did mine this post would be helpful!  its not hard, but damn frustrating and scary when its the first time you do it.
« Last Edit: July 23, 2009, 10:33:09 AM by d3buttz »
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #4 on: July 23, 2009, 10:44:28 AM »
Like Gordon said, get yer hands on the shop manual. That's all I had and it was pretty straight forward.
The only tip I can think of is make sure you use the 550 gear.
1974 CB550
Forever West
Offline Mdub
  • Xspurt
« Reply #5 on: July 23, 2009, 11:08:58 AM »
When you reinstall the valve cover,  be sure to rubber band each intake rocker to each exhaust rocker (#1 int rubber banded to #1 exh., rubber band around top of valve cover) to hold the rocker arms up.
Otherwise, the rocker arms can get jammed and break when you tighten the valve cover bolts.
Mike
X= an unknown quantity
Spurt= a drip under pressure!
Offline buffalogt750
« Reply #6 on: July 23, 2009, 12:19:23 PM »
Download the shop manual from this website. It will tell you everything you need to know. You have to use 550 cam gear because 650 chain is different from 550 chain.You should check lobe clearance in head. My 1976 550 had no clearance issues but apparently some do. You cannot leave the 550 tach driven gear in the valve cover. It will not mesh properly with the 650 cam. If you want a working tach you need to use the 650 tach driven gear and 650 tach. 550 tach cable will work. If you don't care about a tach you need to remove the driven gear from the valve cover and plug the hole. Other than that it's a pretty basic installation.
1976 Honda CB550K   SOLD
1993 Ducati 750 SS
2000 Suzuki Bandit 1200
Offline NickC
« Reply #7 on: July 23, 2009, 12:43:08 PM »
http://www.mrcycleparts.com/?mcp=mr&uid=273452
If anyone doing the 650 cam swap needs a 650 driven gear.....I talked to clint at motoline and have one on the way....
Offline nrd2052
« Reply #8 on: July 23, 2009, 01:31:28 PM »
 ;Dwow ;D
thanks for all of the advice! I am much more comfortable doing this now.
I will report the findings from my "Ass-Dyno" once i get it all buttoned up!
I really appreciate it, guys!
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #9 on: July 23, 2009, 03:12:31 PM »
There is a write-up in the FAQ section with pics.  Slip the cam shaft under the chain from the right side first.  Slide the sprocket on next, then set the shaft into its bearings.  Set the crank at TDC, the shaft notch at 9:00.  Drape the chain over the sprocket then lift the sprocket into position.  Put in one bolt, rotate crank 360 degrees and put in the 2nd bolt.  Torque 'em down and on to putting the head cover on!
WARNING:  Be sure to back out the tappets ALL THE WAY and tie back the rockers BEFORE setting the head cover on top of the head!
This can all be found in the FAQ, forum posts and your shop manual.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
