Author Topic: Advanceing timing and plug temps  (Read 773 times)
Offline Burnboy
« on: July 23, 2009, 03:47:56 PM »
I just advanced my timing in my k5 by 15 degrees. I read that this will increase my plug temp by 70-100 degrees Celsius. That seems like a lot. Im already running d7ea plugs do I need to switch them for something else to handle this extra 100 degrees of temperature?
1975 CB750
1973 CB350F
Offline Burnboy
Re: Advanceing timing and plug temps
« Reply #1 on: July 23, 2009, 09:27:25 PM »
bump
1975 CB750
1973 CB350F
Offline KeithB
« Reply #2 on: July 24, 2009, 04:22:12 AM »
The higher number is a COLDer plug so try a D8EA.
Check this link to NGK...
http://www.ngksparkplugs.ca/tech-info-spark-plugs.cfm
Nanahan Man
Offline BlackMax
« Reply #3 on: July 24, 2009, 09:34:01 AM »
Wow, that's a lot of timing (unless you advanced it from previously being retarded).  Where is your initial spark set?   Is the motor stock?
Yea, I'd probably run an 8 though.
1978 CB750SS, 4-1 Yoshi, Pods, 3-angle valve job, ported chambers, ported intake, 41a cam
