Author Topic: '76 F float level - help needed  (Read 960 times)
Offline JohnG
  • 1976 CB750F - original owner
« on: July 24, 2009, 06:13:11 AM »
hi
I have a box stock 1976 CB750F.  I have the carbs off and would like to set the float levels  (they may never have been checked).
I have a float level gauge and the Shop Manual  (I think it says 26 mm).
Here is my question:  if I put the gauge under the floats (it is essentially U shaped) and against the bottom of the carb, on my stock carbs there is an indentation about 1/4" wide where this would happen. Do I put the float gauge into the indentation??  It is right beside the float on each side.  This makes a difference of 1-2 mm in the setting.
OR should I remove the rubber float bowl gasket and put the gauge against the bottom of the carb where the gasket just was??
In other words - the 26mm setting is a measure between the bottom of the float just as it closes and . . precisely what surface ??
         many thanks!
         John
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
Offline gregimotis
  • poet laureate; SOHC4.
Re: '76 F float level - help needed
« Reply #1 on: July 24, 2009, 07:30:35 AM »
I have the same bike and had to make the same decision:
I made a measuring tool and split the difference by setting it against the inside rim of the gasket lip.  I made sure every bowl had the same height and I haven't had any problems since.
Someone who knows or sure will probably be along shortly but I suspect a millimeter up or down won't have a significant effect as long as the bowls are the same within that range.
Another problem I had was getting the gasket in properly so it didn't hang up on the float later, and cleaning everything off the hinge assembly (scotchbrites and pipe cleaners)
Offline Chester345
  • will someday be an...
  • 76 CB750F
« Reply #2 on: July 24, 2009, 07:48:49 AM »
From the top lip, same bike as you.  This site had a wealth of knowledge for me in the tuning stages of my learning...
http://www.salocal.com/sohc/tech/float_tool/float_gauge.htm
(750F's are the best)   ;D ;D
Offline JohnG
« Reply #3 on: July 24, 2009, 12:19:12 PM »
Thanks , guys!  That is exactly the information I was looking for.
Great carbs to work on... just finished working on the CVs that came with the DOHC models from 79 on . . . what a nightmare!!!
Measured them and they are all off by quite a bit so this is worthwhile.
The motor is out having some oil leaks fixed and this is a good time to fine tune things.
         thanks again
             john
« Last Edit: July 24, 2009, 04:03:23 PM by JohnG »
1971 CB450
1979 CB750F
1982 CB900F
andy1976
« Reply #4 on: July 24, 2009, 02:01:34 PM »
Amen.
I mesured my carbs with the gasket seals off. Seems OK.
Andy
« Last Edit: July 24, 2009, 02:04:14 PM by Andy1976 »
