Author Topic: Centerstand rubbing chain  (Read 2707 times)
damn_yankee
« on: November 20, 2005, 05:25:30 PM »
Now that my K8 is running well, I'll have to fix a few more items to make it truly road worthy. First is the chain/centerstand issue.
The chain is rubbing on the centerstand. See attached pic. What is wrong here? I'm not sure if this is the right centerstand for the bike or not... The chain is not drooping so what gives?
Thanks All,
Jeff
Re: Centerstand rubbing chain
« Reply #1 on: November 20, 2005, 05:28:28 PM »
The stock exhaust has a bumper to keep the stand out of the chain.  You will have to fabricate a stop now that the stock exhaust is gone.
Buffo
« Reply #2 on: November 20, 2005, 06:01:19 PM »
there is a post on that subject...do a search...I think someone even describes a good fix.
I just took my stand off...it goes back on real easy if you need it for some task
damn_yankee
« Reply #3 on: November 20, 2005, 06:08:41 PM »
Thanks. I'll get some metal plate and attach a stop. Next up is fixing the right turn signal and new tires...
Offline Jonesy
  • Shop Rat
« Reply #4 on: November 21, 2005, 12:30:49 PM »
The easy fix is to cut a small piece of aluminum bar stock and attach it with the rear footpeg bolt.
eldar
« Reply #5 on: November 21, 2005, 12:39:54 PM »
Your stand should not rub at all anyways, stock exhaust or not. I changed my pipes but kept the headers but my center stand has never rested against my exhaust. My kick stand does, but not center.
Offline Egil
SV: Centerstand rubbing chain
« Reply #6 on: November 21, 2005, 02:39:48 PM »
It rubbing when your bike stands still, don't it  ???
when you sit on the bike hvere are your chain then  ??? ???
Egil
73 de La2vpa.
Egil.
On The Edge.....That`s Where We Live Every Day.
My bike :
http://bike.no/member/photo.php?id=1605
Buffo
« Reply #7 on: November 21, 2005, 02:41:24 PM »
Egil...I beleive that your english is getting better.  ;D
Offline Egil
« Reply #8 on: November 21, 2005, 02:48:17 PM »
i got google ABC Check , it do really help , don't ya think SIR! ???
You are a SIR isn't yyyou ?
He..He.. ;D
Egil
73 de La2vpa.
Egil.
My bike :
eldar
« Reply #9 on: November 21, 2005, 02:51:24 PM »
Naw not buffo! ;D
Offline Egil
« Reply #10 on: November 21, 2005, 02:58:09 PM »
Don`t you think that the bike raise when you get of (goes of ) the bike  ???,
Egil  ???
73 de La2vpa.
Egil.
My bike :
Hop on a Honda
« Reply #11 on: November 22, 2005, 03:08:46 AM »
I had the same problem with the wrong shockies The Konis were too long replaced them with YSs and Bingo.Worked
BUT The Center stand needs to be held away from the Chain by way of a modifcation from the rear foot peg bolt.
Dave
