Author Topic: Finally! Running like a champ.  (Read 691 times)
Offline BlackMax
« on: July 25, 2009, 10:44:34 AM »
As some of you guys know, I've gone through all sorts of stuff with this bike.  I'm the one that found an extra 5 pounds of debris clogging my oil pump (immediately after a top-end rebuild  >:().  Then, I had the problem where it had ZERO power under load (immediately after a "professional tune")...etc. etc. etc. etc.
Well at the end of the day,  I  disconnected all the leads to and from the coils; then reattached them.  I then cleaned all the plugs (for the 50th time) and fired it up.  All was well  on the kickstand.  So far so good.  That was last night.
Well, I just took it out for a run.....and it's running smooth and perfect.  All throttle levels, all rpms, and pulls like an ape from 6k - 9k.     ;D
thanks for all the help.   All along, it looks like the problem was bad connections at the coils.
« Last Edit: July 25, 2009, 11:26:38 AM by BlackMax »
1978 CB750SS, 4-1 Yoshi, Pods, 3-angle valve job, ported chambers, ported intake, 41a cam
Offline luder
Re: Finally! Running like a champ.
« Reply #1 on: July 25, 2009, 11:09:48 AM »
congrats great when it works out I think I will check all that tommorrow
Offline BlackMax
« Reply #2 on: July 25, 2009, 11:32:20 AM »
You know, I'll mention one other thing, that definitely threw me off.  Of course, I am not that experienced; so, this may be well known to everyone else.
Spark plug wires-  if #1 is not grounded, #4 WILL NOT fire.  So, if a boot is ill-connected to the wire, not only will that cylinder have a problem but so will it's coil partner.  This is also a possibility in my case.  I did re-attach all the boots in conjunction with re-connecting all the coil leads.   It's something to keep in mind, or add to the list things to check when 2 cylinders cut out.  My $.02
