Author Topic: Cleaning the caliper - part deux  (Read 1430 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: July 26, 2009, 10:16:19 PM »
So Simple Green took off most of the caked on crud inside the caliper but the inner surface is a tad rough - especially inside the caliper seal groove.
Synthetic 0000 steel wool isn't aggressive enough. I don't want to hit it w/ sand paper.
I was thinking of running a Dremel felt or cloth polishing wheel around the groove. I'm guessing the wire wheel would be too rough & remove too much material from the caliper. But the cloth wheel should be more gentile.
Like these:
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/AttachmentsDetail.aspx?pid=423E
Any suggestions??
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
Re: Cleaning the caliper - part deux
« Reply #1 on: July 26, 2009, 10:20:01 PM »
Have a brass wire wheel for the Dremel? (I have a couple that came in some super-mega Dremel bit kit I scored at Costco many moons ago)  Should be a lot easier on the aluminum. . ..
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
« Reply #2 on: July 26, 2009, 10:23:15 PM »
I believe I used wet/dry crocus cloth that I oiled. I don't know what the grit rating of crocus cloth is. Next to nothing. This allowed me to just clean it up rather than attempt to be abrasive. It also allowed me to cover the full length of the bore at one time so as not to hit just 1/8-1/4" sections at a time like a dremel would which might unevenly groove it slightly.
