Author Topic: Kerker Exhaust Question  (Read 1393 times)
Offline psniff
« on: July 27, 2009, 04:14:55 PM »
so I got a kerker header off ebay a couple months ago for my 1974 CB550 and just finally got around to installing. The problem is that the exhaust shims dont fit around the header...so either I got the wrong header or I have to use different exhaust shims, mounting hardware etc. Which one is it?
Kerker Header
Stock Header
1974 Honda CB550K
2009 KTM 200 XCW #2039
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: Kerker Exhaust Question
« Reply #1 on: July 27, 2009, 08:21:47 PM »
Wrong header!
My Kerker doesn't use those shims.
The mounting flanges are part of the header.
Offline psniff
« Reply #2 on: July 27, 2009, 09:41:40 PM »
that wasnt what I wanted to hear :(
1974 Honda CB550K
Offline HB-1fan
« Reply #3 on: July 28, 2009, 09:25:06 AM »
Just open them up a little and they will work. They don't affect the seal, just push the flare(seal) against the copper washer.  I have never bought a used kerker that came with flanges. Although the are a slightly larger diameter than stock, I'm not sure new kerkers had them either. Hope this helps!!
HB
"If you always expect the worst, you can never be dissappointed, only surprised"
Offline HB-1fan
« Reply #4 on: July 28, 2009, 09:26:49 AM »
HB
I mean shims not flanges
HB
Offline psniff
« Reply #5 on: July 28, 2009, 09:35:37 AM »
what do you mean by open them up?
1974 Honda CB550K
Offline HB-1fan
« Reply #6 on: July 28, 2009, 12:38:44 PM »
Assuming the larger kerker diameter is the problem! Find something near the kerker diameter(preferrably solid) and tap or squeeze them(carefully) over it until they fit that diameter.
HB
Offline psniff
« Reply #7 on: July 28, 2009, 01:59:50 PM »
I just put the shims in a vice and it worked mint, thanks a lot for the help ;D
1974 Honda CB550K
