Author Topic: rear brake leak  (Read 796 times)
Offline cudjo
  • CUDJO
rear brake leak
« on: July 28, 2009, 10:10:28 AM »
after cleaning and remounting my rear brake, i little bit of fluid will leak out of i press the lever all the way down repeatedly.
the piston was in pretty good shape, as far as I could tell, and I used a new seal?
am I gona have to buy a  new caliper and piston?
Offline punch455
Re: rear brake leak
« Reply #1 on: July 28, 2009, 10:59:31 AM »
Are you sure it's leaking from the piston seal? Check the bleed screw and hose bolt first.  Wipe everything off and pump the brake up.
'78 CB750F
Daytona Bars
Bar-end Mirrors
Custom Rearsets
Offline cudjo
  • CUDJO
Re: rear brake leak
« Reply #2 on: July 28, 2009, 02:15:41 PM »
Pretty sure, I wiped everything down b4. I'll check it out again.
