Author Topic: 1976 Honda CB550 restoration project  (Read 13604 times)
Offline epoch1984
Re: 1976 Honda CB550 restoration project
« Reply #25 on: November 30, 2009, 10:51:19 AM »
this is the naked carb taken down to the smallest componets i can do.
im not a mechanic, but im learning so much from this bike its crazy...  just the carb system alone is very complicated.. cant wait till i work on that engine next week lol
« Reply #26 on: November 30, 2009, 11:10:11 AM »
You still need to pull out the pilot jet.
Offline epoch1984
« Reply #27 on: November 30, 2009, 11:13:49 AM »
not only do i not know what it is, i dont know how to do it
« Reply #28 on: November 30, 2009, 11:27:13 AM »
See the big post cast into the bottom of the carb?  Right next to it is a smaller brass post.  That's the pilot jet, which supplies most of the fuel need for the engine to idle.  It is alos the smallest fuel orifice in the carb and the most prone to clogging up when tainted fuel gets in the carb.
The jet is pressed into this carb.  It is a compression or interference fit.  The jet is grabbed onto with a pliers and yanked straight out.
I find it easier when using parallel jaw pliers. (see picture)
With the jet out, you can clean it properly, verify it is clear, and also clean the drilled passageways in the carb body as well, making sure all four exits/inlets are functioning as they must.
Offline Flying J
« Reply #29 on: November 30, 2009, 02:34:28 PM »
What is the small piece in the upper right corner? It does not look familiar to me.
« Reply #30 on: November 30, 2009, 03:22:57 PM »
With this style carb, I believe it is the needle jet.
