Author Topic: Engine locking up - What should I look for? - Fixed...  (Read 3527 times)
Offline KB02
« on: July 29, 2009, 10:42:06 AM »
So I was finally getting my Cam timed in. I got the Webcam 41A set to open at 27 degree BTDC. I was down to the last cylinder getting all the valves set at .040 and all of a sudden the engine would not turn forward anymore. I tried turning it backwards, but I am only able to turn th engine one full rotation. It's like something is blocking it from turning any further. I looked everywhere I could down from the top end but could not see anything.
What should I be looking for?
It's lunch time, so I'm taking a little break from the heat and eating some pizza. I'll go back out after lunch, but I'm really at a loss. It had been turning fine all morning long.
« Last Edit: August 01, 2009, 06:02:43 PM by KB02 »
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline honda750k
Re: Engine locking up - What should I look for?
« Reply #1 on: July 29, 2009, 10:58:21 AM »
Your cam timing is off and one or two of your valves are touching a piston at TDC
These bikes dont die, they hibernate until the right person wakes them up again.
Offline KB02
« Reply #2 on: July 29, 2009, 11:09:21 AM »
That's the first thing that I though of, too, but I checked all of the valves and the only one that is open enough to hit is actually closing at the time of the hit. I'll double check, though.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline KB02
« Reply #3 on: July 29, 2009, 12:23:12 PM »
Okay. You were right, it was a valve. I loosened up all the tappets and the engine rolls again. Looks like I was off by a big a mount. I reset my timing sprocket and now I'm just a little bit retarded... the timing... not me... I'm a lot retarded...
This is what I'm after:
I saved mine...
Valve lash:  Intake .004 Exhaust .004
Lift:                     .360            .360
Duration:               280             280
Duration@.050        260             260
Lobe Center           103             103
Intake opens 27 Befor TDC Exhaust Opens 53 Before BDC
Intake closes 53 After BDC Exhaust Closes 27 After TDC
Valve timing is checked with zero valve lash @.050 inches of valve lift
Thats what the card says
I'm at 21 degrees BTDC at .050, duration of 233 with a Lobe center of 116.5.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: July 29, 2009, 12:46:25 PM »
When I timed my Webcam the open/close #'s did not match the provided timing card, a common problem. These cams have a "square" profile, look at the #'s and you'll see what I mean (intake: 27/53, exhaust: 53/27). When finding initial sweet spot, just make sure you have "mirror" #'s on intake/exhaust,  ex: 24/57 - 57/24
Just to say, if you set intake open to 27 BTDC and then find that intake close is way off, don't be surprised. I set mine to square and then measured at different inches of valve lift. I think mine matched the card at .038 lift. Hope this helps  :)
Offline KB02
Re: Engine locking up - What should I look for? - Fixed...
« Reply #5 on: July 29, 2009, 03:32:52 PM »
Well, I've got timing set at 26 degrees BTDC on the intake @ .050. The engine turns no problem now.
I might have to diddle with it a bit more to get it sqaure. Or I might just go with it as is. Or I might just leave it and run it the way it is. We'll see.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline scondon
« Reply #6 on: July 29, 2009, 04:11:49 PM »
What is your intake close # ?
Offline KB02
« Reply #7 on: July 30, 2009, 04:31:45 AM »
31
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
« Reply #8 on: July 30, 2009, 04:49:56 AM »
 I'd be more concerned with the exhaust valve as that is the one closing as the piston is ascending. If it is closing real late you will smack it. I'd also measure piston to valve clearance 10 degrees before and after TDC
Offline scondon
« Reply #9 on: July 30, 2009, 09:31:40 AM »
31
That's a 22 degree difference from the timing card. I would suspect that the cam is 11 degrees out of position. Webcam timing cards can't be used as is. There's just no skipping measuring both intake and exhaust to make sure cam is "square." If you want to advance or retard a few degrees you can do it at this point.
Offline KB02
« Reply #10 on: July 31, 2009, 04:08:29 AM »
Alright. I will back it down from 26 to 15 and remeasure everything. I will report back with the new measurements. Might be tonight, but most likely not until the weekend.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline KB02
« Reply #11 on: August 01, 2009, 06:24:21 PM »
Okay, to the best of my timing ability, the Cam is square.
Here are my measurements taken with 0 lash and at 0.050 lift:
Intake opens at 17 degrees BTDC
Intake closes at 40 degrees ABDC
Exhaust opens at 40 degrees BBDC
Exhaust closes at 17 degrees ATDC
Overlap: 34.00 degrees
Intake Duration at 0.050: 237.00 degrees
Exhaust Duration at 0.050: 237.00 degrees
Intake Installed Centerline of 101.50 degrees ATDC.
Exhaust Installed Centerline of 101.50 degrees BTDC.
The top section are my measurements. The bottom section was calculated using the tool on Webcam's website. Duration is certainly off from what Webcam boasts of 280. I'll double check the lift tomorrow before I button the top end up, but I don't think it's quite 360. Then again, they don't, technically, list the duration at .050, they just list a duration.
http://www.webcamshafts.com/index_blank.html?pages/vehicle_search.html
Motorcycle - Honda - CB750 SOHC 8v - 41a
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
« Reply #12 on: August 03, 2009, 05:20:38 AM »
Those LC #'s look good.
Offline KB02
« Reply #13 on: August 04, 2009, 04:34:26 AM »
.330 lift with 0 lash. not quite 360, but that's what I measured anyway.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
« Reply #14 on: August 04, 2009, 04:50:29 AM »
Oh I know what you mean........... ::)
