Author Topic: My Dunstall CB750  (Read 55934 times)
Re: My Dunstall CB750
« Reply #125 on: August 03, 2016, 10:42:07 PM »
What size tire is that?  It looks good.
Scott
140/80/18 Bridgestone BT45
Offline Rookster
« Reply #126 on: August 07, 2016, 08:01:59 AM »
I got the bearings and retainers out of the wheels and polished the rear outer edge.  Wet sand, black, brown, and white buffing compound finished up with some Simichrome.  The original paint on the wheels is a very light silver and I want to try and stay with that color.  I broke the bead on the front tire and started to take it off but my tire spoon put a gouge into the rim so I stopped.  I'm going to have to take it to a shop and have them do it.  I got a quote on powder coat but I thought it was high at $120 per wheel.  I was also considering having the wheels vapor blasted and just cleared.  I got a nice quote from Noblehops but it would involve shipping the wheels from NY to AZ and back so I will probably try to stay local and settle for powder coat.
HenryAbePolish by Scott Rook, on Flickr
Finished the front and the rear polish and now ready for powder coat.
photo 4_zpsj7gwn7vj by Scott Rook, on Flickr
Scott
« Last Edit: July 01, 2017, 07:54:12 AM by Rookster »
Offline Rookster
« Reply #127 on: February 24, 2017, 02:54:13 PM »
I had the Henry Abe wheels powder coated with Prismatic Powders Heavy Silver.  It has a silver flake in it that is very hard to catch in the pictures.
HenryAbePowder2 by Scott Rook, on Flickr
HenryAbePowder3 by Scott Rook, on Flickr
HenryAbePowder4 by Scott Rook, on Flickr
I have a few other updates in the works for this Spring also.
Scott
« Last Edit: July 01, 2017, 07:46:56 AM by Rookster »
« Reply #128 on: February 24, 2017, 03:04:36 PM »
Beautiful!
« Reply #129 on: February 24, 2017, 03:44:25 PM »
Gorgeous!
Offline Rookster
« Reply #130 on: February 24, 2017, 05:49:06 PM »
Thanks guys.  I just voted for the Park Racer.  Nice job Stev-o
Scott
« Reply #131 on: February 24, 2017, 05:57:18 PM »
Appreciate that!
Offline Rookster
« Reply #132 on: April 29, 2017, 01:02:19 PM »
I just mounted new tires for the new wheels.  I went with the Metzeler Lasertec front in size 3.25H19 and the Metzeler ME77 rear in size 4.00H18.  I wanted to stick with the oem sizes rather than get close with metric conversions.
HenryAbeWheelsMetzelerTires by Scott Rook, on Flickr
Next steps are to switch over the disks and sprocket.
Scott
« Last Edit: July 01, 2017, 07:44:21 AM by Rookster »
Offline Rocky2010
  • Live in Strayla
« Reply #133 on: May 02, 2017, 06:17:33 PM »
What brand paint, what colour paint did you use to paint your engine?
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
« Reply #134 on: May 02, 2017, 09:48:10 PM »
Dang it.
I just drooled on my keyboard. Again.
« Reply #135 on: May 03, 2017, 10:59:24 AM »
Scott
Great looking wheels.
Offline Rookster
« Reply #136 on: May 03, 2017, 04:05:28 PM »
The engine paint is Duplicolor Engine Enamel.  The color is 1650.  As always thanks for the kind words guys.  I should have the wheels mounted up in the next week or so.  I have to paint the disk centers on the front and paint the disk holder in the rear silver to match the wheels.
Scott
« Reply #137 on: May 04, 2017, 06:47:34 PM »
Beautiful.
Just gorgeous!
Offline Rookster
« Reply #138 on: June 09, 2017, 08:19:13 AM »
Spring 2017 Update:
The big change this Spring was the 19" front and 18" rear Henry Abe wheels.  They were powder coated Heavy Silver and I polished the outer lip on each rim.  I went with Metzeler Tires in the original sizes; ME77 rear 4.00x18 and Lasertec front 3.25x19.
Dunstall_June_2017 by Scott Rook, on Flickr
I wanted a better headlight than the Phillips sealed beam that was in the bike.  I had an old Wipac headlight and I fitted it with a Halogen bulb.
HPIM2477 by Scott Rook, on Flickr
LucasHalogenReplacementBulb by Scott Rook, on Flickr
WipacHeadlight by Scott Rook, on Flickr
I am in the process of adding a CB900 oil cooler.  I have to work out the mounts but everything is almost ready to go.
OilCoolerPlate by Scott Rook, on Flickr
OilCooler by Scott Rook, on Flickr
I also changed the rear brake stay to an aluminum bar with pivoting ends to accommodate the sliding Hurst Airheart caliper.
HenryAbeRearWheel by Scott Rook, on Flickr
Scott
« Last Edit: August 10, 2017, 06:43:12 PM by Rookster »
« Reply #139 on: June 09, 2017, 09:21:45 AM »
Outstanding work, Scott.
The Henry Abe wheels look fantastic.
I really like the CB900 oil cooler, too.
Offline Rookster
« Reply #140 on: July 03, 2017, 09:55:52 AM »
Headlamp update:
I updated an older Wipac headlamp with Halogen and LED bulbs.  The Wipac was a less expensive replacement for Lucas headlamps on British motorcycles.  Like the Lucas headlamp they had an incandescent main bulb and an incandescent pilot bulb for running in the daytime.  I updated the main bulb to a specialty Halogen bulb that fits into the Lucas headlamp and I replaced the pilot bulb with an LED.  When the main or high beam lamp is on both the LED pilot bulb and the Halogen bulb light.  When the key is turned all the way to the last position (parking light), the pilot bulb and tail light bulb are on.  This combination throws alot more light than the old sealed beam I was running.
Both bulbs on.  You can see the bright white of the LED and the yellow glow of the Halogen:
Key in the parking light position with just the LED pilot bulb on:
Both bulbs on:
Scott
