Wow, lots to do!
Achmed and OldSchool are dead on, here's some more...
Look in the fuel tank for rust, or in the carb drain tubes, if you've got rust, sorry to say, carbs may need cleaning again
![Angry >:(](http://forums.sohc4.net/Smileys/default/angry.gif)
Fuel should definitely flow down both fuel lines, at the same rate, look for a clogged filter or petcock or pinched fuel line.
You'll probably need new plugs, no telling how old they are.
Tappet adjustment is easy, and very important.
Static timing can be set on a non-running bike.
Look for rusty electrical connection on the ground strap and other places.
Fresh oil
And on and on...
![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
Oh, and set the kill switch to 'ON' (Yeah, I did that, for like 30 minutes one day)
By the by, what sounds exactly is the bike making when attempting to start? When you work the choke, does the sound change?
You've got a great bike and they're tons of fun to wrench and ride on, welcome to the forum.
-Tim
