Author Topic: Fork Seals  (Read 2930 times)
Offline CB500_k2
  • Wrenching makes a good retirement.
Fork Seals
« on: April 19, 2005, 05:00:01 PM »
I spent the winter rebuilding a CB 500.  I put new seals in the front fork.  The fork pipes were in good shape with no apparent dings in the chrome.  After 300 miles I found that both forks were leaking oil. Is there a proper way to insert the seals in the aluminum part of the fork?  I inserted the seal with the end of the seal with the slight taper going in first.  I am wondering if this was the proper position. Any help would be great.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline Warlock
Re: Fork Seals
« Reply #1 on: April 19, 2005, 06:17:06 PM »
Greets,
The seal should be installed with the seal lip facing upward(out). If installed improperly, upside down or damaged during installation, the seal can leak. It is important that the seal be driven into the lower fork case perfectly aligned and fully seated against the stop. If the seal is installed even slightly cocked or deformed by excessive force, it will leak. The seal lip would be angled against the fork tube causing rapid wear and elongation. If the sealing lip is damaged by the slightest nick, it too will cause leakage. It is important that the seal be installed using pressure only on the outer perimeter of the seal without contacting the sealing lip. If the taper you are referring to is the taper from the outer edge of the seal to the center sealing lip, it should be facing up. As a rule, seals are usually installed with the seal number facing out when used in a blind opening. Hope this helps...
Ride On...
Offline CB500_k2
Re: Fork Seals
« Reply #2 on: April 19, 2005, 06:42:47 PM »
Thanks for your feedback.  I installed the fork seals with the numbers down and did not completely seat the seals. There was a chamfer on the seal on the side with numbers on it and I assumed that this was the end to go into the fork bottom case.  I drove the seals  in just enough to get the snap ring in to secure the seal.  Looks like I need to redo the seals.
1973 CB500
1974 CB350 - sold
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
Re: Fork Seals
« Reply #3 on: April 19, 2005, 07:15:51 PM »
The oldmanhonda.com web site has great directions
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
Offline kghost
Re: Fork Seals
« Reply #4 on: April 19, 2005, 08:47:51 PM »
If you have some bad spots on the forks or if you install the seals from the bottom up The following trick may help.
I take a roll of wax paper (like from the Kitchen) and put a piece around any area that may damage the seal as I am positioning it. Put a little fork oil (Automatic Trans Fluid?) on the wax paper and seal and slide it over the tricky parts.
Stranger in a strange land
Offline n9viw
  • Floyd, '76 CB550k
Re: Fork Seals
« Reply #5 on: April 20, 2005, 09:50:26 AM »
I read a great article on fixing nicks in fork tubes by super-cleaning the tube with degreaser and a brass brush, then filling the pits with JB weld, and sanding it down to level with the fork. Not a glamorous (or permanent) fix, but enough to keep you from ripping up fork seals too much.
Nick
'76 Honda CB550k
'73 Honda CB750k
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Fork Seals
« Reply #6 on: April 21, 2005, 01:51:33 AM »
Dig it out and we'll publish it!
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Harry
    • CB500F
Re: Fork Seals
« Reply #7 on: April 21, 2005, 01:53:53 AM »
« Last Edit: April 21, 2005, 02:17:42 AM by Harry »
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
