Hey all. I found the site due to some trouble I'm havin. More than a regular on forums so I know how to behave. Hi! I have a 1972 CB500 chop that was put together here in LA by Venice Choppers. Its a cool little bike that I've run to Mexico and all over So Cal.
I needed to replace the gasket between the jugs and the cylinder head and now, I'm at a loss. Due to my incredible skills, I put the cam shaft in incorrectly. I cycled the motor by hand to TDC. Then adjusted the first set of tappets. I cycled though again and when I got to TDC, it stopped, dead. I pulled it open and realized my mistake. Flipped it, reinstalled, and then TDC, adjust, rotate and it again stopped dead at TDC. I pulled it apart to look at valves and they all seem to be seated well. I'm wondering if I am missing something. Someone suggested looking at cam followers. I'm not the real deal, I do some work, but am not versed. Anyway, anyone have suggestions as to what might be stoppin
me at TDC? The motor turns fine until I adjust the valve tappets. The cam chain is free of debris or kinks. Thanks in advance.
