Author Topic: Who would be interested in a HotSyncing tool?  (Read 4587 times)
Offline simon#42
  • liverpool
Re: Who would be interested in a HotSyncing tool?
« Reply #25 on: August 02, 2009, 05:56:58 AM »
deltarider your english is fine ....... you should hear my dutch !
by weak i mean that the fuel mixture is lean or there is insufficient fuel
Offline Deltarider
« Reply #26 on: August 02, 2009, 07:20:19 AM »
Thanks. I always wondered if measuring temperature with simple sensor rings between the plug hex's and the head could be useful. I guess measuring temperature someway at the top of the plug (where the cap goes) is not, unless it could give you a clue to equalise maybe.
Question is: do we want exact data or just a tool to equalise temperature in the four chambers.
Measuring EGT or headtemp could be integrated in the engineguard I described sometime ago. http://forums.sohc4.net/index.php?topic=44306.msg463126#msg463126
« Last Edit: August 02, 2009, 08:03:37 AM by Deltarider »
CB500K2-ED Excel black
Offline Soos
« Reply #27 on: August 02, 2009, 08:55:36 AM »
Does the sensor read the inside of the pipe or outside? I see some variables with wind drafts, ect if the sensors are on the outside.
Not to also be a downer, but I dont see a major gain over a good carb sync.
not for a replacment of a carb sync, a additional tool for max top end power is all.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Soos
« Reply #28 on: August 02, 2009, 08:56:56 AM »
What benefit would this have over an O2 sensor set-up?
Dunno.
I've used both.
l8r
-=≡ Soos ≡=-
Offline Soos
« Reply #29 on: August 02, 2009, 08:59:44 AM »
I'm not going to completely give up on the idea. At the very least this thread pointed out some areas that would need to be looked into if I wanted to develop something useful :)
Brandon
Even Einstein discussed things that were impossible, proved wrong, or went nowhere.
Without discussion, progress would stop as a society
l8r
-=≡ Soos ≡=-
Offline Deltarider
« Reply #30 on: August 02, 2009, 11:45:45 AM »
Now don't you start with this Einstein fellah, boy. He is an imposter, making people to believe that the faster you go, the younger you return. He is a con man. Maybe you'd better not ask how I found out - *3&#@*%!! - but he is the reason me and my Julie split up.
Curse him, CURSE HIM!
Offline simon#42
  • liverpool
« Reply #31 on: August 02, 2009, 12:03:31 PM »
you need to measure the plug temp , as you said between the head and the plug . im not sure what use this would be on a road bike , as soos said it would only be useful to determine the size of the main jet even then you would have to get the bike flat out for a long time before the temp stabilized
for racing two strokes i used a cougar data logger with exhaust gas temp , plug temp , detonation counter and throttle position sensor to determine the needle type and main jet size . a bit over the top for our road bikes i think !!
deltarider dont tell me ......... you went out for a ride one day and came back too young for her !
Offline Deltarider
« Reply #32 on: August 02, 2009, 01:50:18 PM »
Well... what can I say... Looking back... It's all so embarassing... But then, if more members want to know my story (and if moderators will allow me) I might tell you (I said I MIGHT!).
In the meanwhile, stay away from this Einstein fellah. He's a lier and a troublemaker! A troublemaker that's what he is.
Offline Achmed
« Reply #33 on: August 02, 2009, 03:14:19 PM »
I want to know the story. The moderators might allow it in the open forum. Maybe. Serious business here, these internets.
Offline Deltarider
« Reply #34 on: August 03, 2009, 01:23:13 PM »
Well, since you all insist (sigh), here’s the story. In spite of distance in age (she 23 and me 50) Julie and I had a wonderfull relation. She benefitted much from my experience as an older man and I enjoyed her experience that seemed to have come to her so naturally. But… turning 50, I started to wonder if I would remain attractive for her much longer. Not that I was worried sick, but every now and then, I would face the mirror to look for any signs of aging, that Julie could soon detect. Accidentally by this time, I was reading a book, I had found in a secondhand bookshop. It was called The Unbearable Relativity of Species, if I remember well and was written by someone by the name of Einstein who claimed to be a professor.
(to be continued in the open forum)
http://forums.sohc4.net/index.php?topic=56115.0
« Last Edit: August 03, 2009, 01:24:48 PM by Deltarider »
