I don't quite understand. Has the fuse blow problem gone away? Is it a charging problem? Are you having both problems at the same time? If you are still blowing fuses, do they blow quickly or only after running the motor for a while? Is the fuse reed (metal strip) melted in the middle or does the fuse melt under the cap?
