Author Topic: LED Bulbs  (Read 1047 times)
Offline 1974CB750rider
  • 1974 CB750K4 46000 miles
LED Bulbs
« on: July 31, 2009, 08:46:45 PM »
I'm looking into changing my tail light and blinker lights over to the LED bulbs. The bulbs are easy to get, just a bit more $$$ than regular bulbs. The big questions are, would the flasher still work right if you put these in your blinkers and would a ballest (I think I spelled that right oh well had a beer or 2 now) have to be installed.
People with closed minds cannot learn new things.
Offline B.O.X.N.I.F.E.
  • The Stumped
Re: LED Bulbs
« Reply #1 on: July 31, 2009, 09:35:37 PM »
I just spent a couple days reading up on this and placed an order with superbrightleds.com last night.
First, the answer to your question is no, the mechanical flasher will not work. You can get an electronic flasher at most any autoparts store.
Based on what I read replacing the flashers wasn't worth it. They aren't used enough to justify the cost of LEDs, in my opinion. I did get the 22$ rear 5 watt. That, coupled with colored LED's through the whole cluster, and a relay on the headlight will make life easier on my charging system. I also got a RearAlert off ebay to flash the new brake LED, so I don't expect to get rear ended anytime soon.
I would like to replace the front running lights with 3 or 5 watt LED's, but that's for another day & paycheck.
1974 CB550
Forever West
