Author Topic: early 70's carbs on 78 750k... probs?  (Read 803 times)
Offline jordanp
  • creepy Mc creeperson
« on: August 01, 2009, 01:53:12 PM »
I recently found out the carbs on my 78 k are from a way earlier model. The bike was running super rich, and I had to get different cables to get the throttle to work. Was it running rich, possibly, because the carbs are earlier models with a more rich jetting? Should I be looking for carbs from my year? I know it is a pretty bonehead question... and I should just mess with the jetting to get it to run right, but I broke a tab off the float pivot thingy anyway, and no matter what have to replace one of them... I would just assume find a set off a 78 and clean, and sync them. Any suggestions?
Projects > Time
Offline Bill/BentON Racing
    • BentON Racing
Re: early 70's carbs on 78 750k... probs?
« Reply #1 on: August 01, 2009, 07:03:12 PM »
Early model carbs worked real well,you also need early model manifolds and not sure about stock box we were usually using stacks or K&Ns.Your bike came with 26mm carbs,early ones 28mm.Bill
BentON Racing Website
BentON Racing Facebook
Offline jordanp
« Reply #2 on: August 01, 2009, 07:24:50 PM »
hmmmmm. so maybe I ought to find a set of cheap carbs and replace parts as needed.
Projects > Time
