Author Topic: front wheel bearing removal  (Read 6632 times)
Offline MIKE550/4
« on: August 02, 2009, 01:14:31 AM »
hi all
need some help, having battled hard to get this retainer off  thought it would be easy to get these 2 bearings actually out, tried drifts, rawplug idea was mentioned, had a go but will not budge
at a standstill on bike now till i get theses bearings out,  any tips guys   cheers  mike
78 550 k3  ( uk bike )
front wheel
Offline mystic_1
  • 1970 CB750K
Re: front wheel bearing removal
« Reply #1 on: August 02, 2009, 05:27:21 AM »
Take a BFS (Big F#$^ing Screwdriver) like a large #3 phillips. stick it into the about two inches and then pull sharply to one side.  The center collar between the bearings should shift to one side ever so slightly.  Now you should be able to get a drift to engage on the inner race of the bearing and drive it out.  Remove spacer, flip wheel over, and drive the other one out.
mystic_1
- John Augustus Shedd
Offline Bill/BentON Racing
    • BentON Racing
« Reply #2 on: August 02, 2009, 06:40:31 AM »
Ditto that advice,it will work!Bill
BentON Racing Website
BentON Racing Facebook
Offline Johnie
« Reply #3 on: August 02, 2009, 06:45:10 AM »
Here is a pic of the spacer you are trying to move out of the way.  You need to wedge it over a bit so your drift can get a good bit on the edge of the bearing.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Flying J
« Reply #4 on: August 02, 2009, 07:51:30 AM »
here is what i use. $40 @ harbor freight. Works like a champ.
« Reply #5 on: August 02, 2009, 08:41:34 AM »
Ditto on everything and one more tip. Heat the hub with a heatgun or torch. Don;t melt it just hot to the touch, this expands the Aluminum and when you give them a good shot they will come out.
Offline Johnie
« Reply #6 on: August 02, 2009, 09:42:34 AM »
Hey Bobby....this is a familiar thread... ;D
Oshkosh, WI  USA
Offline MIKE550/4
« Reply #7 on: August 09, 2009, 10:58:53 AM »
cheers guys, heat round the hub did the trick
in my excitement though when inner part came out did not notice what end of spacer goes where, does the smaller flanged end of spacer go to retainer side ?
thanks again
pic to show small flange left hand side
« Reply #8 on: August 09, 2009, 11:46:20 AM »
you may want to wait for confirm but IMO the flanges simply keep the spacer somewhat centered so the axle can pick it up on its way thru. Once the axle is in the flanges do nothing. So it wouldn't matter which way it goes.
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: August 09, 2009, 12:39:59 PM »
Agreed, I don't think the flanges touch anything at all once it's all buttoned up.  And I think the inside of that bore is straight, so it shouldn't matter at all.
mystic_1
« Reply #10 on: August 09, 2009, 12:46:48 PM »
thanks again
I am glad the heat worked. I tried it both ways and heat really helps. Yes Johnie been there done that.
Offline DaytonGuy
« Reply #11 on: August 09, 2009, 01:44:45 PM »
Isn't the front hub on the 550 (maybe 750's too) the one where you can simply pound on the bearing opposite the retainer as if you were pounding it into the hub and it will actually push the other side out??  You need to be very carefull that you don't actually tap the bearing into the center of the hub or you are SCREWED.  Once the bearing side retainer is out, flip the thing over and pound the other bearing back out.
I remember doing this, but I can't remember if it was front or rear; but I think it was front.  Takes the spacer in the middle out of the equation completely.
Offline Johnie
« Reply #12 on: August 09, 2009, 05:12:57 PM »
You may have bent the little tabs on the spacer a bit when you pushed it to the side.  I usually straighten them out so the spacer is centered again before I put the last bearing in.  That way it should be pretty well lined up to accept that axle.
Oshkosh, WI  USA
Offline MIKE550/4
« Reply #13 on: August 10, 2009, 07:02:55 AM »
Daytonguy
all i did was the heat the hub up gently for a few minutes , popped a screwdriver through against the lip couple of hits and it came out,
i suppose refit i wil put bearing in retainer side first, then spacer then bearing in the back, then retainer and axle last, when fitting the new bearings might try the heat the hub first and bearing in freezer trick , bearings seem to fit in fairly flush so will make sure i dont knock it in all the way, that would be a disaster
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #14 on: August 10, 2009, 07:08:17 AM »
I used a B.F. Socket! One that fit around the outer race & smacked it with a hammer. That worked really well.
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline mystic_1
  • 1970 CB750K
« Reply #15 on: August 10, 2009, 08:06:26 AM »
The bearing on the retainer side is held firmly in place in it's bore.  The other bearing is free to float in the hub, it's position is determined by the other bearing and the center spacer.
So, install the retainer side bearing first, then the retainer, then the center spacer, then the other bearing, then rest.
mystic_1
Offline Bodi
« Reply #16 on: August 10, 2009, 10:30:22 AM »
The retained bearing sits on a step in the bore, the opposite bearing sits in a bore with no step - just over the OD of the bearing until it hits the (much larger) inside of the hub.
SO the retained side has a smaller bore (where the spacer sits, anyway) and gets the smaller end of the spacer.
« Reply #17 on: August 10, 2009, 10:38:50 AM »
I'm not a 500/550 guy so thanks for that. Is it the flanged part that's smaller on one end, or the spacer part? Just curious.
I never noticed if its the same on CB750s.
Offline MIKE550/4
« Reply #18 on: August 10, 2009, 11:59:38 AM »
good info guys
diameter of bore of spacer is exactly the same, what is actually different is height the 3 prongs come out from the spacer, approx double the length
« Reply #19 on: August 10, 2009, 12:03:59 PM »
good info guys
Curious.
Sounds like Bodi's got your answer.
