Author Topic: need stock carb specks!!!  (Read 3234 times)
Offline Johnie
Re: need stock carb specks!!!
« Reply #25 on: August 26, 2009, 11:16:00 AM »
Did you check to see what main & slow jets are in there? Sometimes the previous owners do change things around on you. Did you ever do a compression check to see where it stands? Just some things to consider...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
matthewspradley
« Reply #26 on: August 26, 2009, 12:30:40 PM »
well, money is tight and i'm not able to afford all the tools i would like to have. ( compression tester, 4 carb sync, et cetera) although i may be able to rent a compression tester at auto zone.  ill check into it.  i haven't looked to see what jets are in the carb.  i assume the numbers are on the sides of the jets or something, ill give it a look see.
until next time
thanks
matthew
Offline Johnie
« Reply #27 on: August 26, 2009, 01:12:35 PM »
The jet size is marked on the side or top of the jet. Real small so I hope you have good eyes. The main jet is screwed into the emulsifier tube on my early KO, K1 & K4 model. Might be different on yours. The emulsifier tube is the long one in the pic with the holes in the side. The main jet is actually under my thumb with the flat screw head slot in it.
Oshkosh, WI  USA
matthewspradley
« Reply #28 on: August 26, 2009, 04:20:38 PM »
thats exactly what i have, only they're clean. lol ;D ill check them and get back to you.  cant tonight, have church and then work in the morning.
cheers
matthew
Offline Johnie
« Reply #29 on: August 26, 2009, 05:25:27 PM »
cheers
matthew
Ha...bet mine are cleaner than yours now... ;D
Oshkosh, WI  USA
matthewspradley
« Reply #30 on: August 27, 2009, 06:18:17 AM »
haha...  new development, its not the carb or the compression, its a coil.  all i need is to replace it. i love good news.  any tips on where to get one at an economically feasible price?
thanks again
matthew
Offline Johnie
« Reply #31 on: August 27, 2009, 09:08:30 AM »
thanks again
matthew
New or used?  New try Z1 Enterprises.  Used try eBay.  I hate to buy used electrical stuff.
Oshkosh, WI  USA
matthewspradley
« Reply #32 on: August 27, 2009, 09:48:18 AM »
Z1 seems to be the place.  should be up and running correctly in no time.  and i know what you mean, used electrical esta no bueno por nada.
matthewspradley
« Reply #33 on: September 03, 2009, 09:25:55 AM »
hey guys,
went ahead with z1; bought the five ohm coil set.  they just arriver this morning and i hope to have time to install them before i return to work.  wish me luck.  after all this i will tune the carbs real good!!!! lol.
until next time
Matthew
matthewspradley
« Reply #34 on: September 09, 2009, 12:34:27 PM »
installed the coils and still had the same problem.  come to find out the common running to one of my points was cut in two.  fixed that and it runs just fine.  hey,  I'm not a crappy carb mech after all!!! lol.
thanks for all the help
and if anybody needs used coils i have two good ones.  can send pics of an ohm test if need be.
matthew
