Author Topic: Ghetto head gasket fix.....anyone try it?  (Read 2975 times)
Offline zoo mob
« on: August 03, 2009, 11:52:40 PM »
So an old Honda SOHC guy I know told me about a head gasket trick that supposedly works; find a nylon bungee cord that is of a proper length and diameter to fit around the motor and stuff it between the fins, and ride it, cord melts, seals gasket, and then cut or scrape away the excess. Hs anyone heard of or tried this? I'm at the point where I'm getting a little oil on the pants, but don't want to pull the motor until the season is over. Any thoughts on why this would or would not work?
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline mcpuffett
Re: Ghetto head gasket fix.....anyone try it?
« Reply #1 on: August 04, 2009, 12:36:22 AM »
I went with the Raul method of rolled up kitchen roll jammed between the fins seems to work ok and inexpensive  ;)
Offline Alan F.
« Reply #2 on: August 04, 2009, 05:51:21 AM »
I haven't heard of that one either, but if it works...it works.  Just remember that when you get your engine apart you'll have to clean the stuff off if you go that route.
I've seen the trick where a short length of appropriately sized cotton rope was tapped between the fins with a screwdriver and mallet, it absorbs quite a bit of oil and is easily replaced.  I'd try that if mine leaked enough.
Cheers.
-A
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #3 on: August 04, 2009, 05:58:57 AM »
I never heard if the technique so can't really comment.  It might work to seal a head gasket, assuming it is the head gasket that is leaking.   Often it is the "pucks" that leak.
The paper towel method is quick and cheap and easily removed.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline 1timduke
  • '75 CB550
« Reply #4 on: August 04, 2009, 10:20:22 AM »
Is that also known as a paper towel?   Never heard that term before, but that's what I'm thinking of.
-Tim
The only thing I miss about the South is Waffle House!
Offline Spanner 1
« Reply #5 on: August 04, 2009, 12:14:46 PM »
Ah the beauty of being separated by a common language.....!!!
   U.K.     Kitchen Roll                          =         U.S.     Paper Towel
              Spanner                                                    Wrench
              Shop                                                        Store
               Garden                                                     Yard
               Yard                                                         Concrete lot ( space )
               Housing Estate                                           Sub-division
               Council Estate                                            Projects ( Gov. Housing )
               Bum                                                          Ass
               4x2  ( always large dim. first ! )                      2x4
               Loo, Jacks, Toilet, Bog                                  Restroom
               Restroom                                                    Waiting Room at a train station.......there's lot's more...!
Offline Toxic
« Reply #6 on: August 04, 2009, 12:23:28 PM »
you forgot bullocks = balls.  It took me forever to figure that one out.
also what it means to be chuffed, still not sure on that one .lol.
Sorry for the hijack, this could go on forever.
Offline Spanner 1
« Reply #7 on: August 04, 2009, 12:27:56 PM »
Almost forgot the most important one....!
  U.K.       Mars Bar                     =              U.S.     Milky Way
               Milky Way                  =                           Mars Bar.......!!
'Chuffed' = very pleased with oneself....!
Offline dave400
  • Super Lamb Banana
« Reply #8 on: August 04, 2009, 12:47:34 PM »
Not quite a correct translation but you’re nearly right, “Bollocks” can = balls but can also mean you disagree with something.
“Dogs Bollocks”, is all about being chuffed, I think it’s all based on the fact that dog’s can lick theirs and they seem happy doing it. ;D
Cheers
Offline Inigo Montoya
« Reply #9 on: August 04, 2009, 01:05:19 PM »
So we are derailing huh!
How about bonnet = hood
boot = trunk
This could be a WHOLE thread all its own! :D
Offline fmctm1sw
« Reply #10 on: August 04, 2009, 04:15:49 PM »
My favorite:  Knackered.  I laugh every time I see that word...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: August 04, 2009, 05:31:37 PM »
Don't forget "fanny".
Offline 1974CB750rider
  • 1974 CB750K4 46000 miles
« Reply #12 on: August 04, 2009, 06:58:22 PM »
I have the same problem and am curious about the paper towel trick. Wouldn't  the paper towel just get hot and burn up?
People with closed minds cannot learn new things.
« Reply #13 on: August 04, 2009, 07:11:41 PM »
According to Kurt Vonnegut, you will need to get to Fahrenheit 451 before paper will combust.  Besides, once it is oil saturated, you will need to get to oil's combustion point.  I did this trick fro a few years with no issues.
Sure.
Is it hard?
Offline shizzomynizzo
  • It's 5 o'clock somewhere
Re: Ghetto gasket fix.....anyone try it?
« Reply #14 on: August 04, 2009, 09:09:00 PM »
what about faggot = buch of sticks or meatballs
or fag = cigarette
I found these out one year on vacation. took a whole day to stop laughing when i was 14 or so!
btw sorry to hijack
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: August 04, 2009, 10:25:51 PM »
If your engine is getting hot enough to ignite paper then you have much worse problems than a gasket leak! :o ;D
Offline moham
  • .fnord.
« Reply #16 on: August 05, 2009, 06:31:34 AM »
or fag = cigarette
btw sorry to hijack
That's one of my favorite lines from Family Guy, Peter saying "Somebody tell this cigarette to shut the hell up..."
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
« Reply #17 on: August 13, 2009, 01:21:58 PM »
I just tried the paper towel method and it worked great, Thanks Guys
