Author Topic: mmmm, DOT legal LED headlight...  (Read 10280 times)
Offline ColinMc
  • There aint no pickle like a super pickle...
« on: August 05, 2009, 06:59:02 AM »
http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=64057&langId=-1
I want that...BAD...too bad it costs more than my CB750 did lol.
It's part number 27250C at NAPA 309.00 over the counter and 199.00 my cost...OUCH!
« Last Edit: August 05, 2009, 07:02:13 AM by ColinMc »
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: mmmm, DOT legal LED headlight...
« Reply #1 on: August 05, 2009, 07:08:27 AM »
60 Watts at high beam, not much energy savings either...
Offline ColinMc
« Reply #2 on: August 05, 2009, 07:10:09 AM »
What kind of amperage does a typical halogen bulb pull at high and low?
Offline manjisann
« Reply #3 on: August 05, 2009, 07:12:23 AM »
To me the only reason to switch to led's is for a savings on energy. I don't know what a typical halogen uses, but if theres little to no savings, aside from the longevity, I don't see an advantage. Other than that, it's a cool item.
Brandon
1980 CB650 Custom
« Reply #4 on: August 05, 2009, 07:14:21 AM »
Normal bulb pulls 60/50 Watts on the 750; dunno about the halogens.
Offline ColinMc
« Reply #5 on: August 05, 2009, 07:25:12 AM »
Wattage doesn't concern me much as long as it's in the ballpark, amperage is where the advantage lies if there is one.
Anyone know on average what kind of amps a stock headlight setup pulls?
« Reply #6 on: August 05, 2009, 07:29:32 AM »
Around 5 and 4 amps.
Offline ColinMc
« Reply #7 on: August 05, 2009, 07:31:30 AM »
So I guess this particular LED light isn't much of a savings...probably better off spending the money on a new harness for the bike and cleaning up the ground locations etc etc lol.
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: August 05, 2009, 08:02:15 AM »
Wattage doesn't concern me [...] amperage is where the advantage lies if there is one.
Umm,
Volts = Watts / Amps
Amps = Watts / Volts
Watts = Amps*Volts
mystic_1
- John Augustus Shedd
Offline ColinMc
« Reply #9 on: August 05, 2009, 08:11:23 AM »
Sorry for my ignorance, but if a 12 volt system is operating a 60watt light...how come the amps used can be different for different types of bulbs? That's why the equations you posted confuse me...
I guess I just always pay attention to the amount of amperage an electrical item uses to determine if it'll be less taxing on the old charging system on these bikes...like turn signals, taillight, headlight...Can't a higher wattage output device (bulb, LED...) pull less amps or is it always going to pull more amps if it's brighter...or should wattage not be confused with actual brightness of the device?
Offline SD750F
    • My Business Site
« Reply #10 on: August 05, 2009, 08:12:46 AM »
The daylight white LEDs really are neither. First they work using a very intense UltraViolet LED emitter that excites a phosphor. The phosphor selected is what color temperature the white LED will be. So you have losses in the UV LED to begin with, the losses with the spectral conversion to the white light. They will still produce heat (more losses) but they will not have mechanical elements such as filaments to break or wear.
So LEDs are perfect for brake and turn lights. Or other marker lights, but really not a good idea for a headlight at this time.
Scott
Offline Inigo Montoya
« Reply #11 on: August 05, 2009, 09:46:55 AM »
I think if a person is going to do something like this, the HID setup is probably a better choice.
Offline Laminar
  • Retsam
« Reply #12 on: August 05, 2009, 09:52:49 AM »
Offers as much as 50x longer life (10,000 hrs vs 400 hrs) than comparable incandescent lamps, saving the time and expense of replacing lamps multiple times
Yeah, I hate having to replace that $20 bulb once every 20 years. This is the perfect solution.
« Last Edit: August 05, 2009, 10:42:12 AM by Laminar »
Offline ColinMc
« Reply #13 on: August 05, 2009, 10:15:30 AM »
Well I got excited because of the "cool" factor and the fact that I THOUGHT it would be much much less power drawn on the system...Well and more for the cool factor lol. People spend quite a bit on HID conversion kits for their bikes. 200 bucks for a LED headlight IF it were a lot brighter and a better quality of light could just be worth it. But like SD750F said, I don't think the technology is probably to the point where headlights like this are worth it yet.
So if I live to be 200 and my CB750 ever gets done before I hit that age this bulb would be pay for itself then right Laminar?
« Reply #14 on: August 05, 2009, 10:18:37 AM »
Yes, that's it.  An illumination device has a conversion efficiency.  Different types of devices convert the power used to produce light in a different manner.
So, don't confuse light output with energy consumption.
Amps is not the defining metric for power consumption.  Watts is that definition.  The equations posted are correct.
Light output is often measured in Lumens.  Further, how the light is measured further complicates a lamps useful rating.  A reflector can focus the light onto a smaller spot.
Then there is the spectrum of light to be measured.  Is all the energy converted to visible spectrum?  What spot size and at what distance?
If a bulb consumes 60 watts of power, it doesn't matter what the light output rating is (from a power availability perspective).
FYI, the stock CB750 headlight was a 50/40 Watt consumption device.  This rating was made on the assumption it was provided with 12.8V.  Because of it's resistive nature, higher voltages will cause an incandescent filament to draw more watts, and lower voltages will cause it the draw less watts.  Note that the light output also changes this style bulb's light output brightness with voltage changes, as well.
Offline ColinMc
« Reply #15 on: August 05, 2009, 10:38:02 AM »
Thanks TwoTired! I was hoping you would chime in at some point...you are great at explaining stuff so I can understand. Electrical stuff always has been and always will be something that just doesn't "click" with me lol.
Offline kirkn
« Reply #16 on: August 05, 2009, 12:59:47 PM »
Well, given a 12-volt system and a 60-watt device, the amps will be constant, whatever the device is that using 60 watts.  Kind of like a pound of feathers vs. a pound of iron.  It's still a pound.  However, for that given 60 watts, different devices may or may not be brighter than others.  Refer to two-tired's description...
Offline 333
  • Time for change
« Reply #17 on: August 05, 2009, 01:20:21 PM »
The other issue to consider is that auto and M/C headlight bulbs are different.  They are subtle, but noticeable if you know what to look for.  The reflector throws the light in a different pattern.  As you sit on the bike, the light shown to the left is aimed lower.  Car bulbs don't have to have this quality, as they can be aimed left and right, as well as up and down.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Gordon
  • 750K1, 550K2
« Reply #18 on: August 05, 2009, 01:27:22 PM »
All of my bikes have an adjustment screw on the right side of the headlight ring so they can be aimed left/right.
Offline mystic_1
  • 1970 CB750K
« Reply #19 on: August 05, 2009, 01:29:05 PM »
My headlight shell can be pivoted left/right/up/down, but then again it's a dune buggy headlight.  :)
mystic_1
Offline 333
  • Time for change
« Reply #20 on: August 05, 2009, 04:53:35 PM »
Yes, there is sometimes an adjustment.  But the angle changes when the bike leans.  The light is angled down on the left so when the bike goes into a right turn at speed and is leaning, it doesn't blind a driver coming from the opposite direction.  Of course, this would have to be reversed in countries where one drives(rides) on the left side of the road.
Offline 74cb750
« Reply #21 on: August 07, 2009, 08:56:37 PM »
Well, around here I like to blind the oncoming driver so he'll see me. ::)
Just kidding 333.
Laugh at least once a day.
Life  $ucks, then you die.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #22 on: August 08, 2009, 12:54:15 AM »
IS there a headlight out there that drams less voltage/amperage than the standard incandescnt bulb?  i'd love to be able to run a smaller battery
Mark Twain - Notebook, 1894
Offline Gordon
  • 750K1, 550K2
« Reply #23 on: August 08, 2009, 01:07:37 AM »
I think true HID headlights use less current, but they require a ballast to provide the initial surge needed to get the light going, which may offset any gain you may get from decreasing the size of the battery.  The electric starter is the biggest draw on the battery, so eliminating that would be the easiest way to allow you to go with a smaller battery.
Offline bucky katt
    • facebook
« Reply #24 on: August 08, 2009, 02:33:34 AM »
so, something like this?  sorry for the hi-jack!
http://www.xtralights.com/index.asp?PageAction=VIEWPROD&ProdID=1349
