Author Topic: Question from a newb! not mechanical  (Read 1720 times)
Offline shizzomynizzo
  • It's 5 o'clock somewhere
« on: August 05, 2009, 05:49:59 PM »
Wondering if all 69 and early 70 750's are sandcast's
I am just curious, as I know they are very valuable and if I by chance come across one for sale for a few hundred, I should buy?
thanks
« Last Edit: August 05, 2009, 05:53:08 PM by shizzomynizzo »
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
Re: Question from a newb! not mechanical
« Reply #1 on: August 05, 2009, 06:13:16 PM »
now, I am not an expert, but I don't think sandcasts even made it to '70.
I am probably wrong.
Present: 1978 CB750A, 1978 CB400A, 1983 Nighthawk 550, 1984 CM250C
Past: 1977 XL100, 1982 KZ1300
Offline Spanner 1
« Reply #2 on: August 05, 2009, 06:20:12 PM »
Here's how I understand it....there were 400 and something sandcast motors made before Honda used a mold to cast the casings and these motors were installed in the first K0 bikes but were not all used-up  before the 'mold' motors began to be installed also....result that some K1's ( 1970 ) had a sandcast motor installed......anyone else ?
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #3 on: August 05, 2009, 06:30:00 PM »
If its a K0 and the engine number is below 7414, call me. ;)
1970 CB750 K0
1975 CL/CB 360 Mix
« Reply #4 on: August 05, 2009, 06:41:17 PM »
good to know! the reason i ask is i found a 69 up north for cheap. it's in sad shape, but I seen a 69 going for 5500 on ebay in the same condition, as it was a sandcast.
is it automatically a sandcast if it has the wrinkle tank?
1974 CB550
2001 Street Glide
Offline Johnie
« Reply #5 on: August 05, 2009, 08:11:22 PM »
As I understand it, a wrinkle tank is on sandcast and also on the ones that are die cast in the 69 & 70.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline honda750k
« Reply #6 on: August 05, 2009, 08:12:57 PM »
I' buy it if its only a few hundred,  way I look at it, if it DOES turn out to be a sandcast, you've got a killer resto project that will fetch hug money.
These bikes dont die, they hibernate until the right person wakes them up again.
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
« Reply #7 on: August 05, 2009, 09:00:38 PM »
I think hug money is illegal... ;p
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: August 05, 2009, 09:20:51 PM »
A wrinkle tank can be put on just about any 750, so no, the tank on a bike may have nothing at all to do with the serial number of the engine or bike itself.
« Reply #9 on: August 05, 2009, 09:23:29 PM »
ok thanks everyone.
If it has a wrinkle tank or a sandcast motor, I will def. pick it up.
If not, then maybe
1974 CB550
2001 Street Glide
