Author Topic: Is it just me or do others have this problem too?  (Read 1302 times)
Offline WrightStuff
    • 1974 CB550 K0
« on: August 05, 2009, 09:21:21 PM »
(Sorry if there are other posts out there on this topic...I searched for a while and couldn't find anything.)
I recently purchased new pipes and gaskets for #1 & 4. I took all the old off and when I went to put everything back together I couldn't get the kickstand to clear the #2 pipe.
It is also not aligned in the back...#2 is too far into the bike...and this is the same exact pipe that was on prior  ???...
And the centerstand does not align with the rubber pad on the pipe...
I took off and re-installed 4 times and even wedged in a block to hold the pipe out while I torqued the nuts down but it eventually moved and blocked the kickstand!  >:(
The only thing I think may have occurred was the center stand whacked the bracket 2 or 3 times with all the pipes off. It seems pretty strong though and not sure that would have bent it but maybe?  ???
Has anyone else delt with this before?
Much thanks in advance!!!!
« Last Edit: August 05, 2009, 09:25:45 PM by WrightStuff »
WrightStuff!
1974 CB550 K0
Offline bender01
Re: Is it just me or do others have this problem too?
« Reply #1 on: August 05, 2009, 09:32:56 PM »
Dont force it!
Did you put the brackets on backwards or inside out? I had a hard time remembering how they went together too. It took me a few tries. I replaced all four and repainted the brackets. Maybe you have the brackets on the wrong side. Those look like 500/550 pipes right?  It will come together. You are almost there.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline WrightStuff
    • 1974 CB550 K0
« Reply #2 on: August 05, 2009, 09:44:35 PM »
Thanks Bender. I actually never took the brackets off - just loosened them.  ???
Yes, thep the bike is a 1974 550 K0.
WrightStuff!
1974 CB550 K0
Offline MickeyX
« Reply #3 on: August 06, 2009, 12:50:01 AM »
I've never seen one of these bikes in person but from the pics, I'd say the pipe needs to run behind the kickstand. Just from the angles you've posted from both ends, that would be my guess. I'm thinking you took them off with the center stand down and didn't notice where it was in relation to the kickstand.
Try it and see. Good luck!  :)
Offline hav150
  • Heavy Metal Flake
    • sohc4 gallery
« Reply #4 on: August 06, 2009, 03:31:29 AM »
#2 should be inside the down tube
Offline WrightStuff
    • 1974 CB550 K0
« Reply #5 on: August 06, 2009, 07:39:37 AM »
Hehe, yes you are both correct.... :-[  No wonder I couldn't find the question anywhere in the archives.  :D
I found this picture to prove to myself that indeed I am a little slow on the uptake at times.  :)
Thanks for the suggestions and bearing with me!
WrightStuff!
1974 CB550 K0
Offline Popwood
« Reply #6 on: August 06, 2009, 10:10:02 AM »
My 550 came to me with the same problem you describe. Struggled with it until I posted a pic here and someone pointed out the pipe belongs inside the side stand. Good ol' POs.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
