Author Topic: 74 CB200 - cylinders do not have same spark plug thread diameter  (Read 1369 times)
Offline earth tones
Is it standard on a 74 CB200 for the two cylinders to have different spark plug thread diameters?  One cylinder has a "B" thread diameter NGK plug while the other has a "D" thread diameter?  Just wondering...seemed strange to me.  Thanks!
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: 74 CB200 - cylinders do not have same spark plug thread diameter
« Reply #1 on: August 06, 2009, 03:46:42 pm »
No it isn't normally common for that to happen from the factory.
What is common is for someone to strip out the threads and to drill and tap new threads for a larger diameter plug.
Which seems to be the case here. Maybe.
Got pics?
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Laminar
  • Retsam
« Reply #2 on: August 06, 2009, 03:54:20 pm »
Nope, my CB200 had the same plug in both cylinders.
Offline earth tones
« Reply #3 on: August 06, 2009, 04:03:33 pm »
I don't have pictures at the moment, but can take some tonight.
Like I said, there is a smaller plug hole that fits a 12mm NGK plug (type D) and there is a larger plug hole at 14mm (NGK type B).  So that must be the case, somebody must of bored out a larger hole and tapped it.  So you just find a plug, with the larger thread diameter, that would equal the performance of the stock plug -- a NGK D-8ES-L??
Offline kirkn
« Reply #4 on: August 06, 2009, 04:43:49 pm »
Yep, my CB200 has NGK D8ES's in it.  Both sides the same.
