Author Topic: 1975 CB550 F.....I'm not even sure what to call this thing any more!!  (Read 21949 times)
Re: 1975 CB550 F.....Fork swap in progress~!! 3/18
« Reply #50 on: March 21, 2010, 04:30:38 PM »
I am using a GSXR rear wheel so with that front sprocket i still had to have a little machined off the rear sprocket carrier but it was the best way to line it all up and still be able to use wider tyres...and a better chain, o ring or x ring chains hit the engine cases, with the offset sprocket you don't have that problem... ;)
Offline verboten1
  • Der König
« Reply #51 on: March 22, 2010, 03:20:14 PM »
thanks for the input!
picked it up, got all kinds of stuff I need, still need to get a caliper mount, and a stay bar.
it's coming together!!!!!
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #52 on: March 23, 2010, 02:54:00 PM »
this will be a tight fit, but I think with a 39 tooth sprocket, it should work pretty well.
the 45 tooth makes it not fit at all....hopefully it will work with the 39, i can go as small as a 36 if needed
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #53 on: March 23, 2010, 03:40:34 PM »
this is going to be a VERY tight fit, but I think the 160 tire on the ninja swingarm will work!
have a 39 tooth sprocket on the way, which will get rid of the sprocket interference
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
Re: 1975 CB550 F.....Fork swapdone....swingarm next!~!! 3/23
« Reply #54 on: March 23, 2010, 03:49:25 PM »
managed to finish up the fork swap this morning.
had to remove 1/8" from the top clamp so i could use the top nut.
1975 CB550F
1982 XV920
2000 KLR65085
Offline KB02
« Reply #55 on: March 24, 2010, 05:51:14 AM »
Front looks nice.  8)
Here is what I did on my "Modern tire" on the stock swingarm.
Started by looking pretty much the same as yours:
The chain was off line from the front sprocket by about 1/8". I was going to try and find offset sprockets to make it all work, but then I got the idea of just trimming down the sprocket carrier by 1/8". (Part #6 in the fiche):
I just had the section that holds the sprocket itself trimmed in - there was plenty of meat there to do it. Now my sprockets (and chain) line right up and I don't have to worry about finding odd-ball replacement sprockets when its time to change them. And still plenty of clearance between chain and tire.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline verboten1
  • Der König
« Reply #56 on: March 24, 2010, 06:34:50 AM »
Thanks for the info!
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #57 on: March 26, 2010, 08:09:39 AM »
I need input!!!!
should I keep the box section swing-arm silver, so it kinda shows off the fact that it's aluminum.....or do i paint it black, to match the frame?
1975 CB550F
1982 XV920
2000 KLR65085
Offline lordmember1969
« Reply #58 on: March 26, 2010, 11:57:07 AM »
Hi:)
Does the ninja swingarm weight less than the Honda swingarm?
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Offline fastbroshi
  • Puppet
« Reply #59 on: March 26, 2010, 11:20:50 PM »
Mick Jagger just said he wants it painted black :P
Just call me Timmaaaaay!!!
Offline Flying J
« Reply #60 on: March 27, 2010, 10:22:11 AM »
My vote is for the aluminum look.
Offline KB02
« Reply #61 on: March 28, 2010, 06:09:43 AM »
I say polish the aluminum.  ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline fasturd
« Reply #62 on: March 28, 2010, 07:04:33 AM »
Brushed aluminum... Polished is a little too blingy. Regardless it is going to look pretty damn cool.
13 in the garage and counting...
Link to my link...   http://forums.sohc4.net/index.php?topic=58422.0
Offline verboten1
  • Der König
« Reply #63 on: March 28, 2010, 09:53:46 AM »
Hi:)
I am not sure, I doubt it is, but i bet it is stiffer
Thanks for the input guys, I kinda like the brushed aluminum idea!
1975 CB550F
1982 XV920
2000 KLR65085
traveler
« Reply #64 on: March 28, 2010, 10:21:46 AM »
39 tooth rear sprocket will work fine with a 17 tooth (stock size) front sprocket.
stock length chain is no longer long enough.
When measuring clearances, keep in mind that tires do swell under riding conditions as they warm up.....so clearance right now, doesn't mean clearance on a hot sunny day at 70 MPH. ;)
Leave the swingarm raw aluminum, IMHO.
~Joe
traveler
« Reply #65 on: March 28, 2010, 10:25:07 AM »
P.S.  Steel wool will make the swingarm look KILLER!....just make sure the "scratches" all go in one direction!
~Joe
« Last Edit: March 28, 2010, 10:27:24 AM by traveler »
Offline verboten1
  • Der König
« Reply #66 on: March 29, 2010, 08:36:25 AM »
I'm going to try out the brushed look!
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #67 on: March 29, 2010, 12:44:02 PM »
just wanted to mock the wheel up in the stock swinger since I got my axle today.
1975 CB550F
1982 XV920
2000 KLR65085
Offline fastbroshi
  • Puppet
« Reply #68 on: March 29, 2010, 01:38:32 PM »
  Can you show us a full length shot?  I want to see what that looks like with the new forks and rear end.
Offline verboten1
  • Der König
« Reply #69 on: March 29, 2010, 01:39:27 PM »
I need to get some bars so i can roll it outside, which means I need risers.
I also don't have the new swinger on yet. need to get some machining done, then i can mount it.
don't have much room in my dining room to get a pic like that!
I WISH I DID!
1975 CB550F
1982 XV920
2000 KLR65085
Offline verboten1
  • Der König
« Reply #70 on: March 31, 2010, 06:16:59 PM »
a little better.....
well I had to mock it up to see how far off my chain would be.....and it's right on with the wheel aligned right and everything....
BUT I need to take some meat off the carrier, and fab up some swing arm spacers....
1975 CB550F
1982 XV920
2000 KLR65085
Offline fastbroshi
  • Puppet
« Reply #71 on: March 31, 2010, 06:23:37 PM »
Sweet, it's starting to resemble a CB-1.
traveler
« Reply #72 on: March 31, 2010, 06:51:08 PM »
looks good
Offline verboten1
  • Der König
« Reply #73 on: March 31, 2010, 06:53:42 PM »
Thanks!
I just have to figure out how i can mount the shock....it will hit the chain because the sprocket is so big...
1975 CB550F
1982 XV920
2000 KLR65085
Offline fastbroshi
  • Puppet
« Reply #74 on: March 31, 2010, 07:06:06 PM »
  How much do you need to clear?  Maybe you could file down the left side of the two parts of that clevis ever so slightly and put a coule small spacers on the right, like what's used to shim RWD differentials when they're setup.
« Last Edit: March 31, 2010, 07:08:41 PM by fastbroshi »
