Author Topic: Overbore cylinder question from newb  (Read 1117 times)
Offline jasonseasen
« on: August 07, 2009, 12:25:04 PM »
Hi,
I picked up a basket case that I have been assembling over the past months. I noticed today I have a set of 65mm pistons and Wiseco rings. However, I will need to bore out the cylinders to allow the pistons and rings to fit. I measured the bottom to the cylinders for their thickness, the inner diameter is 64.2mm and the outer is 68.8mm.
My question, if I bored these cylinders to 65mm, will that leave enough thickness in the cylinders to perform properly? Also, should I be measuring from the bottom of the cylinders or the top?
Thanks,
Jason
Offline Big Jay
    • CBRzone
Re: Overbore cylinder question from newb
« Reply #1 on: August 07, 2009, 02:16:28 PM »
If it is a 750, you can safely bore them to 65 mm, but that is about it.
Jay
« Reply #2 on: August 07, 2009, 02:51:29 PM »
65mm is the ubiquitous 836cc kit. Most popular overbore, hop up kit.
For fun
http://www.nightrider.com/biketech/calc_displacement.htm
Buy it from Big Jay. They can do the boring too.   ;)
Offline jasonseasen
« Reply #3 on: August 07, 2009, 10:33:56 PM »
Thanks!
Also, is there anything specific that needs to be done to the head, besides a correctly sized head gasket? The standard pistons fit nicely under the valves, just wondering if that area needs to be resized?
« Reply #4 on: August 08, 2009, 05:41:19 AM »
Thanks!
Nothing else "needs" to be done. There is plenty that can be done. But its a budget issue, not a technical one.
« Reply #5 on: August 08, 2009, 06:04:13 AM »
Thanks!
  That's gospel MC ::) ;D ;D
Offline Bill/BentON Racing
    • BentON Racing
« Reply #6 on: August 08, 2009, 06:07:27 PM »
Speed co$t money,how fa$t you want to go?,Big Jay sure like 1000cc kit, cylinder and top case 1/2 on way week afer next,on vacation now,Pistons are impressive,whole kit top notch,I think Jeff said if I send Sam Green 2009 Tour T shirt I get 20% off? Cool Thanks,Bill
BentON Racing Website
BentON Racing Facebook
