Author Topic: Help me with my shopping list...  (Read 1915 times)
Offline odin836
  • Honda CB750 K3 (...in pieces...)
« on: August 10, 2009, 03:10:59 AM »
Hello!
I've spent 6 months reading here to build the list below, and have already purchased the parts from CycleX, Z1, PartsNMore, Other.
Still to purchase from Mike and Carpy.
Below is what I have planned, I've not really looked at what standard Honda components should be replaced...
Hoping you all can help!  ;D
My aim is to have everything ready, so there wont be any waiting for parts to arrive once I start the build.
From CycleX
Primary Chains
Primary Chain Roller
Lightened and balanced crankshaft
Adjustable Cam Sprockets
Heavy Duty Clutch Springs
WISECO 836 Big Bore Kit
Cycle X Super Rods
Complete Gasket Set (Suit WISECO 836 Kit)
Gasket Sealer
Oil Seal Kit
Clutch Plate Set
Cam - (hot street to match big bore kit)
Heavy Duty Stud Set
From Z1 Enterprises
Dyna 2000 Electronic Ignition and Coils DDK1-2C CB500 CB550 CB750 4-cylinder (GET 3.0 ohm)
Dyna 2000 Programming Kit
Dyna Ignition Wires - 7mm Suppression Core (Black)
Dyna Spark Plug Wire Crimping Tool
Hook and Pick Set
Internal Circlip Pliers - Motion Pro
Oil Filter & Clutch Hub Spanner
Metric feeler gauge set (25 blades)
Cam Chain - Tsubaki BF05M 94Link - Honda
Tsubaki Chain Link
Cam Chain Roller CB750
Cam Chain Guide CB750
Cam Chain Tensioner CB750
2 x Cam Chain Roller Pin Rubber CB750
Spoke Wrench Set
Brake Bleeder Rubber Cap
Carb rebuild kits.
From Carpy
Clubman Handle Bars
Dunstall Tank
Vincent-Style Seat
Tri-bar Headlight
Finned Aluminium Rear Wheel Spacer
Finned Valve Cover Breather
Stainless Steel Hose Clamps
Braided Steel Oil Lines
Front Fender
Rear Sets
Café Racer Vintage Tail Light Assembly
Café Racer Headlight Visor
Yoshimura 4 into 1 exhaust
From PartsNMore
MAIN WIRE HARNESS LOOM - CB750K (73-75)
BUTTON AND SPRING KIT
Enging Ignition Switch Assembly
REAR STOP LIGHT SWITCH
Horn
Spark Plug Wires
ENGINE OIL SEAL KIT
Exhaust Gasket
19" Front Spoke & Nipple Set
18" Rear Spoke & Nipple Set
Gear Change Leaver
Fork Gaiters
Fork Dust Boots
Shocks
Wheel Bearing
Wheel Bearing
RESERVIOR CAP & DIAPHRAGM
GRAN TOURISIMO STYLE GRIPS
Throttle Sleve
FOOTREST RUBBERS
From Mike Rieck
Stage 3
Kibblewhite Guides
Serdi Valve Job
Guide Removal / Installation
Guide Honing
Stud Removal
Helicoil Repairs
Kibblewhite Springs
Titanium Retainers
Kibblewhite Valves
Other
Tools, 10" Bench Grinder fitted with Saisal Cutting Pad & Buffer (inc 3 grades of cutting compound), Duplicolor Paint (Engine Enamel 2 x DE-1615 & 2 x DE1613) , Small Garage (Carpeted  ;)) and of course my CB750 K3...
What am I missing???
CB750 K3 in pieces.
Offline lordmoonpie
    • Moonpie
Re: Help me with my shopping list...
« Reply #1 on: August 10, 2009, 04:40:08 AM »
Kitchen sink?  :D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline Toxic
« Reply #2 on: August 10, 2009, 04:45:18 AM »
Give it up... that's a comprehensive list...but there are always things you will have forgotten. ;D
Can't remember seeing such a detailed list.  You have obviously done your research.
Are you going to post a build thread under the "Projects" section?
I would love to see this thing come together.
Offline odin836
« Reply #3 on: August 10, 2009, 05:09:51 AM »
I'll start a post in the projects thread in a week or so...
I've rebuilt the carbs, Master Cylinder (i lost part of my soul) and have cracked the case open.
Found my original case was too damaged to my liking so sourced a replacement after a point in the right direction from Terry in Aus.  Unfortunately then cracked a stud in the replacement case, its currently of getting removed at a machine shop.
Cracking the case is the easy part, I'll start a topic in the Projects Thread when I start the rebuild, trust me I'll need the support!  :o
For now, just after advice from others on parts that always need to be replaced during a rebuild so I can obtain them prior.  -- Hate to waste a year of Sundays because a part I need is locked up in a closed parts dealer...
As for the extensive list, I've got it all in excel and will paste it for all to see upon completion, including a total project cost.
My philosophy, leave a place better than you found it.
If I can save someone time and money cataloguing it all then its worth it, everyone here have been very helpful, as I lack experience its the only way I see I can contribute to the SOHC community.
« Last Edit: August 10, 2009, 05:27:26 AM by odin836 »
CB750 K3 in pieces.
Offline lordmoonpie
    • Moonpie
« Reply #4 on: August 10, 2009, 09:24:36 AM »
Toxic is right - you can keep going and going and going but you've got a good list there. Maybe I'd add a set of HD rolled studs for your current list with some tapered steering head bearings and bronze swingarm bushings but you've got the engine covered without heading off into close ratio gearboxes and stuff like that.... should be a great build thread! ;)
1994 Ducati 888 SP5
Offline JAG
  • '74 CB750K, '72 CB500, '76 550K
« Reply #5 on: August 10, 2009, 10:38:33 AM »
Wow....
Do you have an estimate on what all THAT will run you??
I would also love to see this build in it's entirety and in all it's glory...
Looking forward to it.
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
Offline odin836
« Reply #6 on: August 20, 2009, 04:08:38 AM »
So...
Here's whats arrived so far...
I was also given this rim at some stage...
Is this Front or Back?
I might start a Build Thread this coming weekend, depends upon what the other half has planned.
CB750 K3 in pieces.
« Reply #7 on: September 07, 2009, 12:44:10 PM »
Santa has visited you with plenty of goodies?? ;D
