Author Topic: Oil Lines in UK  (Read 679 times)
Offline Skunkmiester
Oil Lines in UK
« on: August 10, 2009, 12:19:07 PM »
Hi there,
just wondering what the best oil lines are that I can use on a 73 CB750 K3?
I would like to have black fittings with stainless hose. I still have the original fittings for the engine side.
Does anyone know where I can get these in the UK?
Some of the stuff that I have seen online are pretty expensive, £40+ for a 45 degree fitting £40 for 1 mtr of hose etc.
I would like reasonably good kit but cannot break the bank as the budget is starting to run dry.
Thank you in advance.
1973 CB 750 Cafe Racer
1992 (original) Fireblade
Offline lordmoonpie
    • Moonpie
Re: Oil Lines in UK
« Reply #1 on: August 11, 2009, 05:21:49 AM »
I got mine from Earls direct on the internet in the UK - very helpful guys there. I re-used my end fittings and ordered new hose and end fasteners. The whole lot cost me £63 BUT I'm running an oil cooler up front so the lines are about 5 times longer than stock so you should get stock lengths much much cheaper.
If you PM me when I'm home later I'll get you the earls product codes and if you're really lucky I might actually have one oil line stock length that you can have for postage cost so you'd just need four hose ends and another line length to save you some £££
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
