Author Topic: soda blasting spokes....  (Read 1416 times)
Offline jamesb
« on: August 10, 2009, 06:54:16 PM »
has anyone tried this yet i was wondering if it worked or not thanks for any input
jimmy
Offline mcpuffett
Re: soda blasting spokes....
« Reply #1 on: August 11, 2009, 01:55:19 AM »
Don't see why it shouldn't  ;), cheers Mick.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #2 on: August 11, 2009, 02:40:47 AM »
i'd be a bit leery of doing anything that removes any amount of material from the spokes. i dont know enough about soda blasting to know if it does or not though.
Mark Twain - Notebook, 1894
Offline Geeto67
  • A grumpy
« Reply #3 on: August 11, 2009, 05:08:52 AM »
it does not. Soda blasting removes the zinc coating - it really doesn't even remove rust (maybe a little). The abrasive media explodes on impact so it is not reusable (like sand), it requires special equipment to spray, and is very expensive., plus cleanup is a nightmare.
that being said are you blasting the spokes because you want to paint them or because they are rusty? and assembled wheel? or loose?
if it is because you want to paint them then just paint over the zinc coating. If it is because they are rusty, well you need a different medium and to be honest considering how small spokes are it is very easy to warp them sandblasting them. plus for what it costs you could just by new spokes and relace yourself. I wouldn;t sandblast an assembled wheel anyway because the sand has a funny way of working into tight spots and never leaving. I have a buddy who sandblasted a wheel and the trapped sand eventually worked free and abraded his inner tube till it ruptured.
« Last Edit: August 11, 2009, 05:10:32 AM by Geeto67 »
Maintenance Matters Most
Offline Caminokid
« Reply #4 on: August 11, 2009, 06:21:19 AM »
At 30.00 a set. I would just replace them. I use soda blast all the time...but it cost me 25.00 a bag for it. Your better off spending 60.00 and be done with it.
God created man...Winchester and a baseball bat made then equal. Evel Knievel
Offline lynchj
  • Life is short ...go for a ride now
« Reply #5 on: August 11, 2009, 01:31:51 PM »
Where can you get spokes for $30 / wheel. Buchanans are ~$90 but they are definitely top notch.
http://www.buchananspokes.net/products/spoke_kits_honda_cb.asp
my CB500 build thread   http://forums.sohc4.net/index.php?topic=54143.0
Other toys: 98 YZ125, 70 MGB, 99 Camaro
Offline mcuozzo
  • Bottle in front of me or frontal labotomy?
    • 77 CB750K - needs total rebuild
« Reply #6 on: August 11, 2009, 06:53:53 PM »
You can try TAS for spokes.  Just ordered a rim and spokes from them.  Really nice people, easy to get a hold of and very knowledgeable,  if I need anything I'll probably call them first from now on.
http://www.tasclassicmotorsports.com/servlet/StoreFront
As far as soda blasting goes, it works to remove paint and light rust.  It does not require expensive (well not really expensive) equipment.  If you have a compressor you can get a blaster from Harbor Freight for about $100.  Soda from a pool store is about $35 for a 50lb bag.  Once you clean things with Soda (or even more aggressive media) you'll never clean things any other way.
For example here is soda blasting vs. coal slag blasting:
http://gallery.sohc4.net/main.php?g2_view=core.DownloadItem&g2_itemId=306810&g2_serialNumber=2
Good luck!
