Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
re-tourque, but there is a good chance you'll have to redo things to get rid of the leak. Did you do anything to check that the head and cylinder surfaces were perfectly flat?
I had a wee leak in the same spot after winding my 500 out to 9000 up a mountain road. got home gave it a little tweak and it has ceased, but...
Did you replace the 6 pucks under the rocker box?
