Author Topic: Mounting tires and bead setting  (Read 878 times)
Offline lowmileage
  • Gotterdone
  • At Montauk Point Circa 1975
« on: August 12, 2009, 11:34:08 AM »
I've mounted new front and rear tires.  Tube type.  I didn't hear the loud "pop."  It looks like they're out to the max of the rim  ??? .  Is the loud pop heard only on Tubeless?  I've initially inflated them to 40 lbs.
1975 750 K5 Original owner -  11K miles.  On the road 8/09 after 26 years in storage.
2004 Harley Superglide - bought new
1973 Honda CL350 - sold in '75 to buy the "750"
Offline honda750k
Re: Mounting tires and bead setting
« Reply #1 on: August 12, 2009, 12:13:30 PM »
tube tires dont make that pop because the bead isnt holding air in, the tube does that.
These bikes dont die, they hibernate until the right person wakes them up again.
Offline lowmileage
  • Gotterdone
« Reply #2 on: August 12, 2009, 12:18:19 PM »
10-4 thanks.   8)
« Reply #3 on: August 12, 2009, 02:15:45 PM »
They often make a little "bump" sound when they finally set. Just do a visual inspection, there shold be a line molded into the tire that will sit right above the rim. It should be the same distance from the rim (1mm or so) all the way around.
Offline lowmileage
  • Gotterdone
« Reply #4 on: August 13, 2009, 06:10:05 AM »
Gotcha on that one.  It's even all the way around.  8)
