Author Topic: Replacement petcock  (Read 963 times)
jonathantaylor86
Replacement petcock
« on: August 13, 2009, 09:01:40 AM »
The petcock on my 72 cb500 is leaking. Can anyone tell me if this petcock will replace the stock petcock on my bike?   http://www.z1enterprises.com/detail.aspx?ID=1745
Does anyone have any other suggestions on a replacement, because the rebuild kits are expensive?
thanks, Jonathan
Offline Triffecpa
Re: Replacement petcock
« Reply #1 on: August 13, 2009, 09:06:09 AM »
pull your petcock off and measure the bung on the tank to make sure that it is the same size.  Also, the 550's used a dual outlet petcock (not sure about the 500's).  You can always put a "T" in the fuel line though and use a single outlet replacement one.
Partsnmore.com has a universal dual outlet petcock.  It's a bit more money ($30 or so I think) and I'm also not sure of the thread size.
Tracy
