Author Topic: Carbs, what do these things do?  (Read 739 times)
Offline Hush
« on: August 13, 2009, 11:31:07 PM »
I've had a few carb problems lately and although I believe that I have cured those I would like to know exactly what these tubes do?
The small vertical tube is the jet pipe from the accelerator booster pump, that much I do know, it's the two small tubes facing you in the photo that puzzle me, anyone?
Re: Carbs, what do these things do?
« Reply #1 on: August 13, 2009, 11:52:14 PM »
Those two tubes are the air jets.  I guess those are mechanical slide carbs.  If so, one of those jets feeds air to the Slow/Pilot/Idle (pick-a-term) jet emulsion tube, and the other feeds metered air to the main jet emulsion tube.
Offline Hush
« Reply #2 on: August 14, 2009, 03:38:09 AM »
Thanks TT  :)
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« Reply #3 on: August 14, 2009, 08:15:29 AM »
The one on the left also is connected to the air cut off valve circuit.
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
