Author Topic: Pressed in jet => screw in jet => ?  (Read 1280 times)
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« on: August 14, 2009, 05:35:28 AM »
We are talking about the OEM PD carbs on 1980 bikes here....
With all the threads about pressed in jets... has anyone ever converted or thought about converting to screw in style slow jets?  Is it even possible without just changing the carb rack which would have a pandora's box of tuning nightmares?
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
Offline Inigo Montoya
Re: Pressed in jet => screw in jet => ?
« Reply #1 on: August 14, 2009, 06:08:56 AM »
Digging thought the past here, I found where someone DID tap the carbs to accept screw in jets. Apparently you have to be very careful as there is not much metal there and you might need a smal amount of locktite to make sure the jets do not fall out.
Offline razor02097
« Reply #2 on: August 14, 2009, 06:34:14 AM »
Really?!  You have a link, or the tags you used?  I searched for a while and couldn't find much about the subject..
Project Rina
« Reply #3 on: August 14, 2009, 07:23:28 AM »
I will see if I can dig it up. It was OLD like 06 or something like that.
« Reply #4 on: August 14, 2009, 07:40:28 AM »
http://www.motorcyclecarbs.com/Keihin_Pilot_Jets_C72.cfm?UserID=1301531&jsessionid=aa3094c9224b1d112257
Different idle jets including press ins.
Now It was done by Buffo who changed his name to south padre don according to old posts.
I have not found what size hets he used but he is the one that has tapped his carbs for screw in jets. I have limited time since I am at work right now so hopefully that gives you enough to go on. Just do a search on his name. Like I said, it was old posts so look in the 05-06 range.
Offline razor02097
« Reply #5 on: August 14, 2009, 07:44:56 AM »
cool thanks  8)
At least I have something to work with now
Project Rina
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #6 on: August 14, 2009, 08:01:18 AM »
I've done this and was on at least one of the previous posts on this topic.  You can basically just screw in the new jet but have to be very careful to keep the straight (after a turn or two it takes care of itself) and don't try to wrench it down too tight.  Use a little oil on the threads the first time, pull it out, clean with gas, then put back in.  I didn't need locktight but it wouldn't hurt.
good luck
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
« Reply #7 on: August 14, 2009, 09:16:13 AM »
Did you just get a standard keihin idle jet or did you have to get a particular size?
« Reply #8 on: August 14, 2009, 09:17:11 AM »
I was working on a '78 750 and used the pilots from a '69-'76 750.
« Reply #9 on: August 14, 2009, 09:32:29 AM »
Well that makes it easy to remember!
Offline razor02097
« Reply #10 on: August 14, 2009, 10:12:12 AM »
I'll check it out
Thanks!
Project Rina
