Author Topic: Jetting Q  (Read 1025 times)
Offline SOHC4ever
Jetting Q
« on: August 14, 2009, 02:55:52 PM »
Hi,
I'm running 105 mains and 38 pilots in my CB750F ('76). The bike has the stock air filter and stock 4 into 1 exhaust.
I did a plug chop yesterday at WOT and they came out white indicating a lean condition at that throttle position.
My question is: how far should I step up the main jets on the first go?
Thanks in advance for your insight.
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: Jetting Q
« Reply #1 on: August 14, 2009, 03:18:34 PM »
i wouldnt go larger than a 110 in it. make sure the airbox is sealed up good, it shouldnt be running lean
Mark Twain - Notebook, 1894
Offline SOHC4ever
Re: Jetting Q
« Reply #2 on: August 14, 2009, 03:36:27 PM »
Do you think that if I find a leak in the airbox, I should do another chop? Cuz that airbox has issues. For one, I can't get it apart. What's the best way to check? Spray some kind of fluid around the seams and see if it bubbles?
Offline bucky katt
    • facebook
Re: Jetting Q
« Reply #3 on: August 14, 2009, 03:54:08 PM »
absolutely, any airbox leaks are going to cause a lean condition.
