Author Topic: Possible/safe to epoxy a cracked coil?  (Read 925 times)
Offline zoo mob
« on: August 14, 2009, 03:54:24 PM »
I have a cracked coil on my bike I'm trying to get run and there is a visible crack in it which is leading to it arcing out, is it possible, safe or likely effective to epoxy the crack and have it function properly?
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Re: Possible/safe to epoxy a cracked coil?
« Reply #1 on: August 14, 2009, 04:22:33 PM »
If it was me Andy I think I would just get rid of it but the experts will chime in. There is a guy here in Kazoo who sells under toddsgarage on E-bay who is a coil freak.Can rebuild any old coil with the new wires etc and is handy with a meter.Did you get the 550?????---Eric
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: August 14, 2009, 04:22:41 PM »
It's OK to epoxy it, however the insulation on the windings may have already been compromised, and simply re-sealing it won't fix that.
Ohm it out, if it reads OK then seal the crack, run it, and monitor closely, that's the easiest way to tell.
mystic_1
- John Augustus Shedd
Offline zoo mob
« Reply #3 on: August 14, 2009, 06:50:29 PM »
Forgive my ignorance on this, but how do I check the ohms? Eric, didn't pick up the 550 yet, going to Flint Sunday to pick it up. Know anyone with a good head for it?
« Last Edit: August 14, 2009, 06:52:11 PM by zoo mob »
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: August 15, 2009, 05:09:30 AM »
Using a multimeter, test between the two spark plug leads.  I don't have the spec handy but it should be in your manual.
Also test between the two input leads on the coil.   Again your manual should list the expected specs.
mystic_1
Offline verboten1
  • Der König
« Reply #5 on: August 15, 2009, 06:01:09 AM »
I have sucessfully done that with coilpacks on my VR6, havent messed with the bike but it can be done, I use RTV because it will flex with the expansion and contraction of the part.
1975 CB550F
1982 XV920
2000 KLR65085
