Author Topic: Brake Pad Frozen in caliper  (Read 1076 times)
Offline quidger
« on: August 15, 2009, 02:28:48 PM »
I'm trying to change the front brake pads on a CB550 that has been sitting in a barn for 5 years. The pad in the caliper with the piston is frozen and I'm having a x#@*! time trying to get it out. I loaded it up with WD-40 overnight, I drilled a screw into the pad  to get some leverage but it ain't budging. Would heat loosen it up? Or any other ideas would be helpful.
Thanks.
Offline Raul CB750K1
Re: Brake Pad Frozen in caliper
« Reply #1 on: August 15, 2009, 02:32:22 PM »
Have a look in the "tips and tricks" section, this subject has been dealt with thoroughly.
Offline Popwood
« Reply #2 on: August 15, 2009, 03:55:21 PM »
Mine was stuck pretty bad but was able to push it out using the brake lever. Let the brake hydrolics do the work do the work of pushing it out. See if you can't pump the lever to push it. But do check the FAQs.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline fmctm1sw
« Reply #3 on: August 15, 2009, 05:41:35 PM »
+1.  If the master cylinder works, it has never failed me forcing one out...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline quidger
« Reply #4 on: August 16, 2009, 06:55:26 AM »
Problem is that there is no master cylinder so I will try grease gun method described in tips and tricks.
Thanks.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: August 16, 2009, 08:56:08 AM »
You could have one hell of a time getting that piston out if one end was exposed to air.
Try the grease gun or about 120 psi, hopefully you can get the wheel and caliper off to make the job a little easier on you. Just make sure you have a backstop to catch the piston if you use compressed air.
