Author Topic: Pictures of my BLUE TURBOCHARGED CB750 ! Finally  (Read 30069 times)
  • Moderator
Re: Pictures of my BLUE TURBOCHARGED CB750 ! Finally
« Reply #75 on: October 07, 2009, 12:04:24 PM »
Offline JLeather
« Reply #76 on: October 07, 2009, 01:15:50 PM »
Blue71, couple more questions.  I notice you don't have a fuel pump (atleast not one I can see).  The ATP kits came with an electric fuel pump when they were new, and they claimed that without one you'd suck the carb bowl dry and blow the motor.  Have you had any problems with fuel flow?  I also can't seem to see a petcock on your tank.  Obviously you run it hard, so if you haven't ran the carb dry by now I'd imagine you won't ever.
Also, I see you're still running the original ATP wastegate that looks like a brick.  I've go one for my ATP kit as well (in fact, it's the same "spider" kit you've got) but I'm concerned about the reliability and adjustability of it.  How has yours been performing?
Offline JLeather
« Reply #77 on: October 07, 2009, 01:28:06 PM »
Also, are you running the stock oil tank?  Is that enough capacity for the extra oil that ends up in the turbo/lines?  I assume you're running an oil cooler?
Offline BLUE71TURBO
« Reply #78 on: October 07, 2009, 03:30:21 PM »
JLEATHER,  I am running an electric fuel pump. I only run it when i know i'm gonna get on the boost hard. The SU carb i'm running has a larger fuel bowl on it so it wont run dry. I'm using a inline petcock from a lawnmower shop, flows more than a stock one. I'm also using the stock oil tank and also have purchased the braided oil lines from RICKYRACER, but I
havn't installed them yet. No oil cooler yet but i'm going to soon.   ;D
« Last Edit: October 07, 2009, 03:57:04 PM by BLUE71TURBO »
Offline Zaipai
    • My Home page
« Reply #79 on: October 07, 2009, 05:30:37 PM »
That's awesome!
Its my Avatar..
75 CB550F  |
