Author Topic: Custom rear signal mount brackets...pics included  (Read 938 times)
Offline dilbone
« on: August 18, 2009, 10:00:35 am »
I've been looking at picking up a rear grab bar for my '75 CB550 after I removed the luggage rack that was on it so I could mount the rear signals.  I decided that 30-40 bucks for the bar just wasn't worth it so I picked up some 1.5 inch x 1/8th inch aluminum and started taking some measurements.
My dad is a toolmaker so I knew if I could get him a decent drawing he could put it together for me.  I thought they turned out really well, he even sand blasted them for me for that nice matte finish.  I cut a couple of pieces out of an old innertube for some dampening between the signals and backets and it all worked out well.   I don't need no stinkin' grab bar!!!!
« Last Edit: August 18, 2009, 10:02:30 am by dilbone »
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Custom rear signal mount brackets...pics included
« Reply #1 on: August 18, 2009, 10:45:40 am »
Looks good to me if it works!
Offline dilbone
« Reply #2 on: August 19, 2009, 05:24:59 am »
it works alright...
I'm sure with some additional thought I could have come up with something more creative, but at this point if people never notice them then I suppose they're doing their job well.  I was thinking about getting out the wet sanding paper and polish to get these polished up but I just wanted to get these mounted proper.  I had been using sections of a gutter hanger as brackets while I kicked around wether or not I wanted a grab bar or not.  This has been a huge improvement over my initial jacked up fix.
Those without grab bars, how have you mounted the rear signals?
Offline KB02
« Reply #3 on: August 19, 2009, 06:02:53 am »
The only thing that would creep into the back of my mind is that it looks easy to rotate them upward or downward by accident with the simply nick of a boot as you're mounting the bike.
They look great, don't get me wrong. How solid are they mounted?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Alan F.
« Reply #4 on: August 19, 2009, 06:11:26 am »
I like them, but I was thinking the same thing.  Maybe a few star washers and some loctite?
-A
Offline dilbone
« Reply #5 on: August 19, 2009, 06:25:10 am »
they're pretty friggin' tight right now...you'd have to really knock'em good to get them to move.  I'm more worried about bending the aluminum than I am about them rotating.  Should have used stainless, but aluminum was more readily available in that size.
Star washers, that's a good idea...may have to run out a pick up a few.
Offline jimbir
« Reply #6 on: August 19, 2009, 06:41:38 am »
Do you still have the luggage rack? Pictures maybe? Want to sell it? Let me know.
Thanx, Jim B.
1976 Honda CB550F
