Author Topic: Signal buzzer,beeper  (Read 2259 times)
Offline beelsamin
« on: August 18, 2009, 12:24:55 pm »
Does anyone know where the signal buzzer is located on a 1978 CB550?
My search query only got me a lot of complaints about them LOL,  but not where it's located.
Thanks
1977 Suzuki GT750
1972 Honda CB750 K2
1978 Honda CB550K
Offline kine8282
  • "Ceteris paribus, my modis operandi is carpe diem"
Re: Signal buzzer,beeper
« Reply #1 on: August 18, 2009, 12:27:08 pm »
they live between the headlight ears. looks like a short salt/pepper shaker
1975 CB550K aka "Nefertiti"
1978 CB750K aka "Kate"
Offline beelsamin
« Reply #2 on: August 18, 2009, 12:40:03 pm »
What does it attach to? I've just aquired it and the rubber housing on it has a slit that allows it to slide onto some sort of metal tang?
I've looked for a mounting spot behind the head light case but I really can't see anything that it would hook onto.
1977 Suzuki GT750
1972 Honda CB750 K2
1978 Honda CB550K
« Reply #3 on: August 18, 2009, 02:31:01 pm »
On the left headlight mount/upper fork cover is a metal tab with a square hole in it.  The buzzer mounts there and faces toward the rider.
« Reply #4 on: August 18, 2009, 04:00:57 pm »
Rather than remove it its a lot easier to unplug it...inside the headlight shell.
good luck
Andy
Offline honda750k
« Reply #5 on: August 18, 2009, 04:51:18 pm »
I've unplugged mine on my 750K and I dont miss the POS.
These bikes dont die, they hibernate until the right person wakes them up again.
rbtconsultants
« Reply #6 on: August 18, 2009, 04:57:44 pm »
I posted a thread last week about replacing mine with  $5 piezo buzzer from Radio Shack and wiring it to the brake light so it only beeps when the brake light  is off. I love this because when I am stopped it doesn't beep, and then when I get off the brake and make the turn it beeps to remind me to turn it off. With a new solid-state flasher my turn signals blink consistently and the beeper works consistently, regardless of RPMs. This makes me happy.
Bob
« Reply #7 on: August 18, 2009, 05:05:31 pm »
For the removal crowd...
The buzzer is a nag so you don't drive down the road for miles with the blinker on like an idiot, further confusing drivers that are already over taxed with driving responsibilities/decisions.  Do you really want to add to their barely achievable work load with added decisions about WTF you might do?
But, if you prefer to do that than have the nag then.... :-X
It also alerts pedestrians that you are turning and just *may" keep them from stepping in front of you.
But, these things are far less important than your riding reverie and self image (some say).
Offline Johnny5
    • CB350F build thread
« Reply #8 on: August 18, 2009, 05:46:52 pm »
Or you can get in the habit of turning off the turn signal...Just like setting the trip meter at each fill up.
That freakin' buzzer lasted about 5 seconds on my ride.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
« Reply #9 on: August 18, 2009, 06:15:37 pm »
Very good Llyod. Well if you need someone or something to tell you to turn your blinkers off then you keep your little buzzy friend. I for one find it a distraction, an irritation and would much prefer the silence when sitting at stop lights...Ill take my chances with the stupid pedestrians thanks. Thats what the HM300s are for. One growl from them and it thins the crowd  ;)
cheers
Andy
Offline BeSeeingYou
« Reply #10 on: August 18, 2009, 11:06:19 pm »
I keep mine for entertainment purposes at stoplights.  The pedestrians looking around wondering where that damn beeping is coming from.  I'll turn my head from side to side pretending I am looking for it too. ;D
Offline honda750k
« Reply #11 on: August 18, 2009, 11:23:05 pm »
5 seconds?  yeah, umm, the MINUTE I saw it, it was being disconnected and unwillingly removed to go into a milk crate of misc parts that displease me and shall one day be sacrificed to the gods of speed.
Offline Dave-and-his-550
  • I know the pieces fit...
« Reply #12 on: August 19, 2009, 01:19:04 am »
hahaha thnkx i got a good laugh out of that
Offline Geeto67
  • A grumpy
« Reply #13 on: August 19, 2009, 08:00:10 am »
actually it's primary reason was as a pedestrian warning system (if you believe early owners manuals). I have to say I kept mine because riding in NYC the thing is effective. YOu should see the ped's heads spin toward me when they hear the beep, keeps the idiots looking the wrong way from stepping out in front of me.
I notched the signal housing on my bike when I found that I could turn the switch enough to turn the blinker on without the buzzer coming on. it is nice to have a choice to use it or not. I basically found the spot in the travel where the light comes on and the buzzer does not and took a miniacule chunk out of the housing with a dremel up to that point. Then I bent the switch down slightly (careful it is really easy to break). so now if I want the buzzer I lift the switch slightly with my thumb and can move it the rest of the travel.
Maintenance Matters Most
Offline beelsamin
« Reply #14 on: August 19, 2009, 09:33:55 am »
Thanks for all the replies, and I'm on the keeping it side.
Mike
1977 Suzuki GT750
1972 Honda CB750 K2
1978 Honda CB550K
