Author Topic: CB750K0 transmission swap  (Read 612 times)
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« on: August 18, 2009, 01:22:16 PM »
Hi Will a 78 SOHC transmission fit my 1970 K0 ? If not which is the last transmission that will fit
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: CB750K0 transmission swap
« Reply #1 on: August 18, 2009, 01:36:47 PM »
yes
Mark Twain - Notebook, 1894
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #2 on: August 18, 2009, 01:38:42 PM »
Basically they should be the same. If you're talking a 78 F-2, the output shaft has a double roller bearing and won't be able to seal an early case with that bearing. 4th & 5th gear are lower gear ratio. Probably some other minor differences, but I believe the hard parts will all fit into that case.
I've done some mix and match and haven't found what DOESN'T work... ::)
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: August 18, 2009, 07:25:03 PM »
You can change out the final shaft bearing to match your case, in certain combinations i.e. shaft has a wide bearing but your case is set up for the narrow one.  There are differences in the locator ring grooves between various cases as well.
If you use all the gears as a set you should be ok.  Some gears sets don't intermix as the tooth pitch or profile is different.
mystic_1
- John Augustus Shedd
